Buying a new L5740 HSTC?
   / Buying a new L5740 HSTC? #101
Haven't been around in a while, congrats on the new tractor TripleR! Definitely a very nice and finely equipped tractor!
   / Buying a new L5740 HSTC? #102
TripleR,
See you finally took the leap - hope you enjoy the new toy. I've had mine for a little over 2 years now. I can't compare it to anything else since it was my first tractor. It's served me well for near 700 hrs now - mostly grapple (in the woods) and field work. Considering your desire for easy access, thought I should mention my experience with my wide turf tires. When I bought my L5740 it came with loaded Ag tires. Even with heavy attachments front and rear, I felt uncomfortable on more than one occasion. Center of gravity just seemed too high sitting in that closed cab. A while back, I bought some wide turfs for this tractors. Not only to protect my newly finished pastures, but to also lower my butt closer to the ground (about 5" lower). These wide turf tires are great. So great, I doubt that I will ever re-install the Ag tires. Although the turfs are unloaded, they're nearly 24" wide and I am easily taking hillsides that once cause extreme pucker factor when the Ag's were mounted.
One final observation - it has been my experience that driving a L5740 across rough pastures/fields will crack ribs and bust kidneys no matter what kind of tires you have mounted. Unless you take them to a golf course finish, you're in for a very rough ride at speeds over 2-3 mph. One other thing - my auto throttle stays off. I prefer to adjust from the column.
   / Buying a new L5740 HSTC? #103
Wish you were closer! I'd certainly be interested in buying those Ag's from you!
   / Buying a new L5740 HSTC? #104
Duplicate post.
Thanks, I hated to spend the money on the extras, but you only live once dang it; not sure I could handle it again though.:laughing:
TripleR,
I sure know what you mean about the center of gravity, height and feeling of stability. The most stable feeling tractor we have ever had and still own it is a Massey Ferguson 375 we bought new with turf tires. You also sit astride the transmission hump lowering your seating position more. That thing was like a mountain goat. I never felt uncomfortable on that tractor. I can't drive it anymore, so my brother has it out at our flatland farm and he put Industrial tires on for better traction.
The L5740 is so similar in size to our old L5030 that I feel pretty confident if not "comfortable" driving it on our hills. My experience has been that the L5030/L5740 is more stable than it "feels". It took me quite some time to develop a certain level of confidence in its stability. My son grew up driving tractors on our hill farms, so his comfort level far exceeds anything I will ever feel. On really steep stuff, I just wimp out and drag the M8540 out; much better for the ole nerves.:thumbsup:
Having grown up driving tractors with steel seats and using non suspension seats occasionally until a couple of years ago, I guess I am more use to a rough ride, so the L5740 doesn't seem so bad though it is far from smooth compared to the M8540. I have posted elsewhere that I have parked the GL and pulled the M8540 in really rough areas at one of our farms when mowing a particularly rough section, other times I just slow down. 4Shorts and DDT have put air ride seats in theirs and I might look into that some day.
Appreciate the input on the ATA as I am in the process of learning to use mine. I only have about six hours on mine and have to admit, I have a lot to learn to take full advantage of the features. The HST "sensitivity" is something I am just not seeing any use for yet and am running it in the middle; any input from any HST+ operators on any of the features is welcomed.
I would love to see some pictures of your 5740.:thumbsup:
   / Buying a new L5740 HSTC? #106
The Grand L series are great tractors and I have been looking at one for awhile now......but I was hoping that Kubota would at least offer 2 options that I'd like to see for the Grand L.
1. An Air Ride seat option.
2. Veritical Exhaust option.
I know Deere has both these options on the 3000, 4000 series tractors and would like to see Kubota offer these also.
Stu
   / Buying a new L5740 HSTC? #107
Stu
This may be true, but it's unlikely that either of these options are better implemented than what 4shorts has done! I understand everyone isn't as mechanically inclined, but I think that's all the more reason for Paul to start marketing his product:)
   / Buying a new L5740 HSTC? #108
What is the advantage of a vertical exhaust?
   / Buying a new L5740 HSTC? #109
1. Looks cool!
2. Doesn't leave the soot on the loader bucket or other parts of the tractor
3. If your working in really muddy or wet conditions there is no chance that the exhaust will allow water/debris in should the tractor be shut off
   / Buying a new L5740 HSTC? #110
Primarily I think it keeps exhaust soot off the loader frame. Disadvantage is it can stick up higher than the ROPS on some tractors so it could limit where you could go. I am sure some people think it looks better as well. Kind of like an old turbo'd Oliver at a pulling contest :shocked:
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
SET OF (3) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (3) ALCOA...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
CAT CS563 (A47477)
CAT CS563 (A47477)
