Snow Any way to plumb a B7100 for a heater?
   / Any way to plumb a B7100 for a heater? #1
Travelover
Elite Member
Washington
B7100
I'm going to drape a golf cart enclosure over the canopy of my B7100 and I was thinking that it might be neat to add some heat. I realize that it has no water pump, but I can pick up an automotive electric auxiliary water pump off eBay for about $50, a heater core for $15 and add a pancake computer fan for another $10.
So, my question is: Is there anywhere to conveniently tap the cooling system to get some hot water?
I added a temperature gauge by inserting a copper tube into the upper radiator hose and I guess that I could add a nipple there and do something similar to the lower radiator hose, but if there is an easier path, I'll all ears.
   / Any way to plumb a B7100 for a heater? #2
I'm going to drape a golf cart enclosure over the canopy of my B7100 and I was thinking that it might be neat to add some heat. I realize that it has no water pump, but I can pick up an automotive electric auxiliary water pump off eBay for about $50, a heater core for $15 and add a pancake computer fan for another $10. So, my question is: Is there anywhere to conveniently tap the cooling system to get some hot water? I added a temperature gauge by inserting a copper tube into the upper radiator hose and I guess that I could add a nipple there and do something similar to the lower radiator hose, but if there is an easier path, I'll all ears.
Shows how much I know, I thought all water cooled engines had a water pump. How does the whole radiator thing work without something to circulate the water?
Sent from my iPad using TractorByNet
   / Any way to plumb a B7100 for a heater? #3
If you are going to use a golf cart enclosure, why not look at a golf cart heater? They run on small tanks of LP. I've got a cab on my B3030 and rarely use the heater. Between the green house effect from the glass and body heat, I stay pretty toasty.
Yea, I may end up there, but thought I'd see if I was missing anything.
   / Any way to plumb a B7100 for a heater? #6
Most diesels have a 17 mm block drain and a 17mm air vent on top the thermostat. Could hook up a circulating system between them.
Ralph
Ralph
This has a thermostat?
   / Any way to plumb a B7100 for a heater? #9
Close in the sides so the fan blows back into your cab.:)
I'm looking at that possibility. I could block the exhaust side screening and make a passageway rearward on the intake side with some sheet metal......hmmm.
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2014 VOLVO VNL (A55745)
2014 VOLVO VNL...
(APPROX. 20) 4' X...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
2019 GALYEAN...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
