Snow Any way to plumb a B7100 for a heater?
   / Any way to plumb a B7100 for a heater? #1
Travelover
Elite Member
Washington
B7100
I'm going to drape a golf cart enclosure over the canopy of my B7100 and I was thinking that it might be neat to add some heat. I realize that it has no water pump, but I can pick up an automotive electric auxiliary water pump off eBay for about $50, a heater core for $15 and add a pancake computer fan for another $10.
So, my question is: Is there anywhere to conveniently tap the cooling system to get some hot water?
I added a temperature gauge by inserting a copper tube into the upper radiator hose and I guess that I could add a nipple there and do something similar to the lower radiator hose, but if there is an easier path, I'll all ears.
   / Any way to plumb a B7100 for a heater? #2
I'm going to drape a golf cart enclosure over the canopy of my B7100 and I was thinking that it might be neat to add some heat. I realize that it has no water pump, but I can pick up an automotive electric auxiliary water pump off eBay for about $50, a heater core for $15 and add a pancake computer fan for another $10. So, my question is: Is there anywhere to conveniently tap the cooling system to get some hot water? I added a temperature gauge by inserting a copper tube into the upper radiator hose and I guess that I could add a nipple there and do something similar to the lower radiator hose, but if there is an easier path, I'll all ears.
Shows how much I know, I thought all water cooled engines had a water pump. How does the whole radiator thing work without something to circulate the water?
Sent from my iPad using TractorByNet
   / Any way to plumb a B7100 for a heater? #3
If you are going to use a golf cart enclosure, why not look at a golf cart heater? They run on small tanks of LP. I've got a cab on my B3030 and rarely use the heater. Between the green house effect from the glass and body heat, I stay pretty toasty.
Yea, I may end up there, but thought I'd see if I was missing anything.
   / Any way to plumb a B7100 for a heater? #6
Most diesels have a 17 mm block drain and a 17mm air vent on top the thermostat. Could hook up a circulating system between them.
Ralph
Ralph
This has a thermostat?
   / Any way to plumb a B7100 for a heater? #9
Close in the sides so the fan blows back into your cab.:)
I'm looking at that possibility. I could block the exhaust side screening and make a passageway rearward on the intake side with some sheet metal......hmmm.
New/Unused Two Post Car Lift 10,000lb (A57453)
New/Unused Two...
Volvo L306 (A57148)
Volvo L306 (A57148)
John Deere 5055E (A53317)
John Deere 5055E...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A56438)
2020 John Deere...
Forklift (A59228)
Forklift (A59228)
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
