3 PT Dethatcher
/ 3 PT Dethatcher #1
Gittyup
Elite Member
Mid Atlantic
Kioti CK25 Shuttle Shift, loaded tires, JD X739
Anyone use one of these?
CMP 3-Point Dethatcher
Or know any thing about this company and this product. How well do 3 Pt dethatchers work vs. town behind? I like that I can raise and back into tight spots and drop it and let it do it's thing.
I get a lot of sticks and debris off my maple trees and thought his would be good, and maybe help with acorns too?
/ 3 PT Dethatcher #2
Unless you really need a de-thatcher a landscape rake would work better on sticks and such. Neither would do much on acorns.
/ 3 PT Dethatcher #3
It looks nice and is reasonably priced. Maybe I'll get one. I don't know if it will do anything for acorns and stuff.
I know my landscape rake is way to aggressive for the lawn. it will take the sticks, stones, grass, soil and everything else.
/ 3 PT Dethatcher
I have a nice landscape rake with gauge wheels. But, it's still too aggressive for grass. What about a pine straw rake? I think this would work on the sticks but how well will it pull up thatch? Yeah, I know the acorns are a tall order. There is a specialty tool that supposedly will gather acorns. Pricey for a one task tool, as I recall. My needs in order of importance are thatch, sticks/depris, acorns.
/ 3 PT Dethatcher #5
nope, but I've been looking for one.
Thanks for posting
/ 3 PT Dethatcher #6
None of those fixed dethatchers seem to do very well at dethatching... seems you need a power unit for that.
For what you want, it seems you'd be much better suited with a tow-behind sweeper. Unfortunately nobody seems to make an economical, heavier-duty version of the el cheap tow-behind lawn tractor sweepers, but I have one on my JD mower and it works very well.
/ 3 PT Dethatcher #7
I have a small Craftsman tow behind dethatcher now and it works well removing the dead grass.
Only issue I see is that its not a tow behind, but since its so close to the rear wheels, might not matter and won't need to add cement blocks to it to get it to dig down.
/ 3 PT Dethatcher #8
Really? I have one and even with cinder blocks on it, it leaves probably 75% of the thatch behind and still stuck. The tow-behinds look EXACTLY the same, must be my grass/ground which prevents it from working. The power dethatchers take almost all of it out, but try running one on 3 acres of grass :p
/ 3 PT Dethatcher #9
I made this to get up pine needles. I guess technically it is a dethatcher. It did rake up a big pile of pine needles. Probably have about $200 in parts, plus my labor, and the satisfaction that I built this. Overall it weighs in at about 60lbs.
The dethatcher that's linked at $269 + free shipping makes it a good deal. Looking at it the main thing I like about mine over this is that mine sits further back from the tractor.
20140218_155908.jpg 20140218_155847.jpg 20140215_142119[1].jpg 20140215_142051[1].jpg 20140215_142037[1].jpg 20140219_164656.jpg
/ 3 PT Dethatcher #10
Well, I'm not doing 3 acres :D, but I also don't cut the grass too short so not too much thatch to get up. The first time I did it, I did the entire lawn one way, went back and did it the other and then dragged it around every time I mowed for the month. By the second month, the lawn was the best its ever been. But that first day, boy did I pull up a lot of thatch.
That looks nice! Something about building things yourself always seems to install a bit more pride.
/ 3 PT Dethatcher
Sure seems like there are lots of users that swear that they work. Maybe not like a vertical slicer/dethatcher, but good enough (or so they claim). I'm going to give it a try. Has to be better than nothing, and I'm not walking 2 acres of ground multiple times with a walk-behind. I will post back once I get to use it after all the snow melts and things dry out: Probably May the way things are going :(
/ 3 PT Dethatcher #12
View attachment 363631 View attachment 363632 View attachment 363633 View attachment 363634 View attachment 363635 View attachment 363636
That's the best executed, weld free implement I have ever seen. Nicely done!
/ 3 PT Dethatcher
Nice job on the home made unit. I'm getting the 50" for $259 and will be using behind a GT. Whats the advantage of being further away from the tractor? I think it will be about 2 feet behind the tractor wheels in my situation. I would think closer is better so that the dethatcher is on the same terrain angle as the tractor. But, I really don't know what is best. I do know that tow behind would not work so well for me because I have too many dead ends with no room to turn. Will have to be: back in, drag through, back in drag through.
/ 3 PT Dethatcher #14
I'm confused, it seemed from your original post you wanted to use it for sticks and acorns - it will grab some sticks but leave the acorns. As a dethatcher it will work okay and a walk-behind isn't feasible. They do make power tow-behind dethatchers but they are $$, if you have a local place that rents them it might be worth looking into.
For that price though they charge, it's definitely worth a shot!
/ 3 PT Dethatcher #15
I bought one like that from everything attachments called "PINE NEEDLE RAKE".It works great for dethatching my lawn.
/ 3 PT Dethatcher
Sticks and acorns are secondary to thatch. My acorns are not thick yet. When the trees get more major I'll probably just get this
Pick Up Small Acorn's with Bag-A-Nut's Tag-A-Long
I think the dethatcher will do good enough pull sticks out of the grass and gathering them, at least partially to make pick up easy.
/ 3 PT Dethatcher
yeah, coobie, I looked at that rake. Decided to save money and get the CMP. I don't have pine needles anyway, and thought the more purpose built for thatch implement would serve me better.
/ 3 PT Dethatcher #18
I don,t have pine needles on my lawn but it works pretty slick dethatching.I also use a 6ft chain harrow for dethatching
/ 3 PT Dethatcher #19
I was looking at the chain harrow too, but that takes up a lot of room and not sure if it does a better job. Since you use both...what's the deal?
2021 Club Car Carryall 500 Electric Utility Cart (A59228)
2021 Club Car...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
UNUSED KJ K1912 - 20' X 12' LIVESTOCK METAL SHED (A60432)
UNUSED KJ K1912 -...
2020 CATERPILLAR 303.5E2 EXCAVATOR (A60429)
2020 CATERPILLAR...
