Seeking advice on welding hook to FEL bucket
   / Seeking advice on welding hook to FEL bucket #41
Do the same weld on the back side as you did on this one (both welded) and hit it, the material will bend before the weld breaks (most likely).
Yeah, most definitely. Actually I think a proper weld and the 1/4" material would bend even if only welded on one side.
What I tried to do was duplicate Shield Arc's example to show the difference in a proper weld and an inadequate weld.
I could do that weld again and based on the weaknesses I see in this example, produce a stronger weld. I didn't get anywhere near enough penetration and my bead is too small. Not enough thickness in the center of the bead to produce strength.
   / Seeking advice on welding hook to FEL bucket #42
   / Seeking advice on welding hook to FEL bucket #43
Here's my second attempt. Same welder setup. Slowed down a little and tried to push my heat more into the vertical piece. Bent the metal this time and had to hammer it the other way to finish the break. Still inadequate when compared to SA's examples. Almost need heavier wire and more power. :)
   / Seeking advice on welding hook to FEL bucket #44
Yes, that is how I did it.:thumbsup:
Here is a Mig fillet weld break test I did.
When I see the break pic I feel a little better. Then I look at the weld pic and I'm so inadequate!!!! :)
What is L56 wire and do you remember the welder settings used??
   / Seeking advice on welding hook to FEL bucket #46
Yeah, but I've been welding for a few weeks now! ;)
My Dad always said "understand your capacities and never try to function above them, you'll get your head chopped off". I have been welding long enough that I understand my capacity. But I'm always willing to learn how to increase my functioning level to that capacity.
Thanks for sharing your knowledge SA.
   / Seeking advice on welding hook to FEL bucket #47
L-56 wire is made by Lincoln.
Here are my Mig settings.
.030" wire flat. 22-volts. 154-AMPS. 400 wire speed.
.030" wire vertical up hill. 21.6-volts. 78-AMPS. 200 wire speed.
.035" wire flat. 23-volts. 160-AMPS. 240 wire speed.
.035" vertical up hill. 18.0-volts. 125-AMPS. 198 wire speed.
.045" wire flat. 21.5-volts. 191-AMPS. 200 wire speed.
.045" wire vertical up hill. 18.5 volts. 140-AMPS. 120 wire speed.
   / Seeking advice on welding hook to FEL bucket #48
So, with my .035 wire, 21V, and 45% (301). I'm running my Voltage too low and my wire speed too high.
I'll try your setting. Thanks SA!!!!
   / Seeking advice on welding hook to FEL bucket #50
Yes, I don't know much so I cold be wrong but would turn up the power and adjust wire speed for better penetration. Maybe smaller diameter wire?
TORO TR20 WALK BEHIND TRENCHER (A51406)
TORO TR20 WALK...
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A55788)
2012 Mack CXU613...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
2022 Toro 21in Hydraulic Walk-Behind Turf Aerator (A52377)
2022 Toro 21in...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
