Large concrete water trough needs repair.. How
   / Large concrete water trough needs repair.. How #1
Cavjock22
Seabrook, TX
Kubota M6060, Bushhog 3210, Deere offset disk, Deere B drill, forks, bucket
Folks
I have an old water trough that's 30-40 years old that hadn't been used for years. It about 10-14' in diameter and about 3' tall. It has developed large cracks in several places. How can I repair this? Any recommendations?
   / Large concrete water trough needs repair.. How #2
Flexseal..
   / Large concrete water trough needs repair.. How #3
hydraulic cement is a possibility, chisel out the cracks so there is a place for the hydraulic cement to mechanical bind into.
a liner could be a possibility,
   / Large concrete water trough needs repair.. How #4
Depending on the size of the cracks you can have different methods.
Narrow crack can be sealed with epoxy. Larger cracks can be widened and repaired with hydraulic cement
So epoxy or hydraulic cement? Would mortar be a possibility? just batch some then spread over cracks. Will it not stick?
   / Large concrete water trough needs repair.. How #6
I was thinking flexseal also but personally haven't used it. Know a couple guys that have and they swore it was good stuff.
   / Large concrete water trough needs repair.. How #7
No,use hydraulic cement or epoxy.
   / Large concrete water trough needs repair.. How #8
A skim coat of mortar will not stick and will break off in pieces that will drive you crazy.
   / Large concrete water trough needs repair.. How #9
Folks
Go to Home Depot (or elsewhere), and buy a gallon of concrete bonding adhesive. ($14)
This bonding adhesive product looks like milk.
Paint the bonding adhesive in the cracks, and let it dry.
Then make a concrete paste of fine sand & cement (with water), and also add some bonding adhesive to the mix.
Coat the cracks for a second time with bonding adhesive, and while that is still very tacky, fill the cracks with the paste.
When dry, coat the trough with two coats of two part epoxy paint.
Flexseal would NOT BE A LASTING FIX for this situation!
2015 CATERPILLAR  XQ30 GENERATOR (A58214)
2015 CATERPILLAR...
2003 International 9200I (A53317)
2003 International...
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
Land Pride RCR1260 (A53317)
Land Pride RCR1260...
2005 TerraGator 8104 (A55302)
2005 TerraGator...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
