First time using a rear blade, man I really suck!
/ First time using a rear blade, man I really suck! #1
Soldier415
Vermont
2001 Kubota L3010GST. 2005 Kubota L3430HSTC
Purchased a Land Pride RB3784 with hydraulic angle a few months ago. I also have top n tilt on the tractor. Had 30 yards of crusher run trucked in and chain spread yesterday to fix a section of road and have enough material to put a proper crown on it.
The material was spread uneven and quite thick. Angled blade 45 degrees and tilted it to have a 4 degree crown. Even going very slow it was a chit show. tractor goes up and down over the uneven spots and the blade dips and rises.
As I said in title, first time using a rear blade for this purpose. I dropped the blade off and attached the box blade thinking if I spread with the BB to get an even flat surface I can come back over it with the tilted blade to crown it.
Any advice for a grader blade noob from those that are experienced?
Pics of how it sits now
/ First time using a rear blade, man I really suck! #2
You understand the problem well.
There are a few things that can help, but nothing is perfect. Dozers cut a nice grade because they are on tracks so little imperfections don move the whole machine, and the blade is in the front so you are driving on what's already been graded.
Some things that help...
1. With loose material like the stone you had delivered, spin blade around and go in reverse. That way the tires stay on the level part you have already graded.
2. Rear gauge wheel if your blade has that as an option.
3. Skid shoes. These aren't real effective in loose material though
1. With the hydraulic angle cylinder I can't swing the blade around. I could still go in reverse just using the back of the blade
2. I have searched and searched but they don't offer a rear wheel with this blade
3. Yeah, don't think it would work that well
/ First time using a rear blade, man I really suck! #4
I will grade alot using the blade backwards; if I am going forwards the blade is turned around backwards, if I am going backwards the blade is turned towards the front. This allows it to drag a mass of rock, drop it into shallow areas and it doesn't have much dig to it.
/ First time using a rear blade, man I really suck! #5
You can turn it around but you'll have to put the cylinder on the other side.
/ First time using a rear blade, man I really suck! #6
You are learning that the 'ol rear blade has a somewhat long learning curve. If I'm grading my mile long gravel driveway and using my rear blade - I do exactly as Birdhunter1 does. Reverse the blade and drive forward. The ups/downs in my driveway just cause the rear blade to dig and dump too often.
As a matter of fact - since I got my Land Pride GS2584 - land plane grading scraper - I haven't used the rear blade for that job any more. The LPGS grades the gravel, the Rhino 950 plows the snow.
/ First time using a rear blade, man I really suck! #7
I'm not good at it either. I am getting better at feathering the 3pt up and down while going very slow.
/ First time using a rear blade, man I really suck! #8
Using the convex portion of the blade vs. the concave section would be best, so just leave it as-is and roll backwards. The rear of the blade should push across/through the high spots and imperfections and you will only drive on more level surface and shouldn't get the dip and dig issues.
/ First time using a rear blade, man I really suck! #9
Hard on the 3pt linkage, no?
/ First time using a rear blade, man I really suck! #10
I am only familiar with granite (crusher run)...but it is much easier to work with when it is wet...when it's "right" if can be spread like butter...
Agree about using the blade turned backwards...also try less of an angle...45* is a lot...try 15*-20*
/ First time using a rear blade, man I really suck! #11
First time you did well :thumbsup: just have practice little more.
Kinda cheating...use front end loader,tip bucket about 45 degree slant w/little down pressure slowly back drag high spot away,than use rear blade for finishing touches.
/ First time using a rear blade, man I really suck! #12
I really don't think it would be that hard on the linkages. Unless something goes seriously wrong - driving in reverse with the rear blade still in the "forward position" has never built up very much material in front of my blade. Max amount I've ever had was 3" to 4". With the blade in the reversed position it just does not dig up that much material. And it tends to dump it all at the very first chance.
If the build-up of material in front of the blade seems to be too much - reverse the blade and drive forward.
BTW - the pics of your driveway look like you have the new material spread pretty well. I'd just take one of your "normal" vehicles(car or pickup) and pack down the center. Or do as Thomas suggests with the bucket on your FEL.
/ First time using a rear blade, man I really suck! #13
Keep it forward, go slow, and set it to float, when set to float is should let the blade move relatively independent of the machine, also cut you angle back a but, 45* seems a little steep, and push it toward the center with the blade set flat, the you can back drag or blade the center a little higher to cut your crown in.
I have a GS1560 LPGS that I use for refinishing. However the driveway is flat and not crowned which is why I wanted more material and use the blade to put a 4 degree crown on it. As it sat before all the water runs straight down and eats away at the bridge abutment.
Went out with the box blade and got a fair amount of it spread. Just hooked the blade back up. Contemplating turning it around and moving hydraulic cylinder
Pretty sure I just did that with the box blade. Went in reverse to smooth out a section but forgot I had extended the top link so the rear facing blade dug in hard. Now the top link hydraulic cylinder is leaking where the piston goes into the cylinder
/ First time using a rear blade, man I really suck! #16
Ditto on this suggestion. Use the front bucket to take out the high spots first
/ First time using a rear blade, man I really suck! #17
Going in reverse with loose stuff works really well. Just take your time and don't get in a rush. Like someone else also said don't be afraid to use your loader to knock down high areas. One last thing to get more of an even control on the up and down of the blade I set the three point hitch arms so the blade is level when on the ground then use my hydraulic top link for fine adjustments.
/ First time using a rear blade, man I really suck! #18
Rear gauge wheels will turn it into a different implement.
/ First time using a rear blade, man I really suck! #19
PJ
You need to get out and try "floating" a rear blade in fresh stone. The blade fills and dives deep, pulling ALL the fresh material off with it. Not a good method at all. And if the blade is reversed, Float does nothing to distribute material unless you just want it to go out to the edges.
I just topped a few feet of my sloped drive . 4 yards of crusher run. The blade sensitivity to load and tractor pitch is the big challenge. Going very slowly, making depth adjustments as you go is about as good as one can do on a first effort. Top hydro control would be handy to better control the blade "bite". It can help to shorten up the top link to take some of the aggressive attitude out of the blade. ;-)
/ First time using a rear blade, man I really suck! #20
Unless a position is set a lowered 3ph is always in float...
2015 GMC Yukon XL SUV (A59231)
2015 GMC Yukon XL...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2016 Chevrolet Traverse SUV (A59231)
2016 Chevrolet...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2016 Ford F-150...
2010 International 4400 S/A Day Cab Truck Tractor (A59230)
2010 International...
