Diesel Stabilizer
   / Diesel Stabilizer #21
Thank you everybody. I did order the Mr. Funnel. I guess since I'm buying my first tractor, I am worried about the whole diesel gelling thing even though we are now in our 2nd day of spring with snow flurries this morning. Hope I won't have to deal with this issue ever.
Generally if you are getting fresh fuel it's formulated for your local tempatures at that time of year.
I have a 300 gallon tank I get filled & shoot for getting it filled in the winter so I'm probably getting winter blend. I also put in Power Service White bottle & a biocide. Neither are likely needed, but I'd rather be safe than sorry.
Speaking of better safe than sorry... Grab a bottle of Power Service red bottle, the 911 stuff. Don't use it unless things gell up & you need too run, but it's a life saver if things get ugly & you need the machine.
Biocides are probably less useful for me as "algae" (not actually algae, but slimy microbes that look kind of like it) is a function of water contamination. My tank is in the barn under a roof. Also I live in Colorado where humidity is a foreign concept. I can't even get a drop of water out of the drain of my air compressor after dozens of hours of running in the winter.
   / Diesel Stabilizer
Well I'll by a white bottle of Power Saver and I received the Mr. Funnel yesterday. I have no idea how that funnel works, but I filled it with water and nothing comes out of it. Dang miracle in my eyes.
   / Diesel Stabilizer #23
This year in SW Colorado we can't even get water out of our downspouts. For March we are at 0.22" precip.
   / Diesel Stabilizer
Stupid question though, is DEF needed for my new Kubota L4701?
   / Diesel Stabilizer #25
It's pretty amazing.:cool: There is always some residual fuel left in the funnel that can be saved for QC in a clear glass container and reintroduced to the existing fuel canister if "good." It does not drain real quickly when temperatures are around "gel point." The gelling can be managed.
   / Diesel Stabilizer #27
So what happens when you run fresh E10 through it? Month old E10?
(Through the Mr Funnel)
   / Diesel Stabilizer #28
I treat all my E10 ethanol contaminated gasoline with Stabil Marine 360. After almost 3 years I’ve eliminate all my constant carb issues and problems with 2cycle chain saws, etc.
We have no local station with ethanol free but Buckee’s opened between Ranch and Houston and they have ethanol free. Next pass I’m picking up 5 gallons for my 2 cycle equipment.
   / Diesel Stabilizer #29
Ethanol can destroy or swell some rubber used in hoses, O-rings or other parts. That's obviously a problem, but easy to work around. Most reputabke OEMs have been specing those parts for years.
Ethanol also attracts & absorbs water. And as everybody knows water & metal don't mix... corrosion. With small engines having vented fuel tanks & carbs, air & moisture can circulate in as temp & atmospheric pressure vary. That gets water in the tank & carbs. Modern automobiles have non-vented fuel tanks & fuel injection. So they don't get air in & out of the system causing condensation & water issues much.
   / Diesel Stabilizer #30
Measuring the Power Service can be a bit of a hassle - I broke the glass measuring cup I found just laying around in the kitchen but you need not mention that to my DW. I use 5 gallon cans and a rattle siphon to fill my tank until I get my diesel stoves hooked up in my shops and start buying 300 gallons at a pop. Anyway, recommended is 1.6 ounces per 5 gallons hard to get precise huh - but what, heck just pour some in, right? Well what I do is save those nifty 2 cycle oil jugs with the measuring container on the top - squeeze the bottle and the oil fills the graduated container so you can pour it into your gas for the proper mix. I refill the empty with Power Service and get a reasonably perfect measurement each time.
Sorry, there are two types of oil bottles, you want the first one as you can easily refill it. The second photo requires the removal of a little valve in the bottle's neck and then replacing it again - all with a long nose pliers.
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2019 GALYEAN...
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
