Building an 8遅16 gooseneck dump trailer
   / Building an 8遅16 gooseneck dump trailer #81
I get that, but why do all flat deck trailers get pin weight added to their GVWR?
Makes no sense
Idk....:confused3: Strange I try and call my load trail dealer on Monday and see what he says....
only option for loading equipment is those miserable ladder ramps. The longer ones are better for loading angle, but then I thought can’t you buy the shorter ones and just tilt the dump up slightly to get rid of the hump at the back edge of the trailer?
   / Building an 8遅16 gooseneck dump trailer #83
Maybe they just do 2 8ks for 16k for safety reasons and liability.....
You often get a lower rating for tandem use than for single use because of skid forces on tires and bearings
   / Building an 8遅16 gooseneck dump trailer #84
only option for loading equipment is those miserable ladder ramps. The longer ones are better for loading angle, but then I thought can?t you buy the shorter ones and just tilt the dump up slightly to get rid of the hump at the back edge of the trailer?
Yes, I do it all the time and I have a low pro. And yes, they are miserably heavy /awkward.
As far a GVW, there doesn't appear to be a standard. Manufactures are all different in how they arrive at their ratings. Some add pin weight, some don't. I think there is more at play than just the axle capacity, the frame, gooseneck and hitch all play a part. Then you add the owner/operator into the mix and you get any GVW, Lol.
But I see flatbed tandems rated 15-20% above their axles.
Could it be the load in a dump trailer is somewhat “ live “ , therefore it could shift and overload an axle?
PJ rates LESS than the sum total of their axles. 3)8k and 21k GVWR. Nice trailer though.
   / Building an 8遅16 gooseneck dump trailer #87
I think in the case of three axles it goes back to my #59 post.
https://www.tractorbynet.com/forums/trailers-transportation/429012-building-8-16-gooseneck-dump-post5816850.html#post5816850
Or copy & paste:
I think part of the GVW rating considers two or three axles. It might not be reasonable to expect one axle to carry the weight of three, but is okay for one axle to carry the weight of two. This is in a momentary situation where the ground is uneven. Dexter does not recommend a three axle torsion, because of this. With springs and equalizers it can still happen but chances are way less.
Or copy & paste:
Yeah I get that, but then why not with a triple axle flatbed trailer?
I see 3) 7k axle trailers rated at 21k or more all over the place.
   / Building an 8遅16 gooseneck dump trailer #89
Yup, my old car hauler trailer was a triple 7k rated at 21k.
My 10t is rated for almost 6k tongue weight (2 10k axles and rated for 20k lbs cargo capacity, trailer weight is about 6k)
My dump trailer has 2 6k axles and is rated at 16,800lbs gross.
What you are looking for is similar to what I want except I need a tag trailer. I want a 18ftx102in wide deckover dump with fold down or removable sides, oil bath 8 or 10k axles with 17.5 tires.
So far i haven't found anyone that makes that combination.
I think what we want would have to be custom, maybe I'll make one some day, maybe even make it a rollback style!
   / Building an 8遅16 gooseneck dump trailer #90
I wouldn’t care to have a pintle hook with a single 20k axel. It would turn so much better. A pickup couldn’t handle the hitch weight of something like that but a dump truck will do fine. I’ve seen some 5th wheel trailers like that but I don’t want a one trick pony truck.
2011 WABASH 53 FT DRY VAN (A58018)
2011 WABASH 53 FT...
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A58018)
2007 CHEVROLET...
2007 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A56858)
2007 Chevrolet...
2015 FREIGHTLINER CASCADIA DAYCAB (A58214)
2015 FREIGHTLINER...
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
2019 Chevrolet 1500 Silverado Crew Cab Pickup Truck (A55973)
2019 Chevrolet...
