Pennsylvania New Home Build Thread. An attempt.
   / Pennsylvania New Home Build Thread. An attempt.
It's been a while since I've updated this thread, but we're always busy.
I built a drop ceiling under my deck and finished it off with metal roofing the drains into a custom gutter system. I also wired and installed 12 low voltage "can" lights which provide just the right ambience at night without being over powering. In the section that is under roof from above, I wired in for a ceiling fan/light (yet to be installed). A few pictures:
We also had our driveway at the house finished somewhat. We finally cut in the circle and the excavator put down a shale/asphalt milling sub base, then rolled it. We will finish it all with millings in the spring most likely:
   / Pennsylvania New Home Build Thread. An attempt. #163
Thanks for the update.
Driveway looks so smooth! Hope it doesn't pot-hole up too badly on ya. What do you think the ratio is of shale to asphalt millings? Looks more grey than black.
Hot tub must be a nice place to spend an hour during sunset. Those lights dimmable?
   / Pennsylvania New Home Build Thread. An attempt. #164
Count me in as still watching and enjoying! Looks good.
That was just the sub-base, and I wasn't there during the application, but I would guess it's 70/30 or 60/40 shale/millings. If/when I finish the driveway with millings, it will be screened washed millings. They put them on with a paver at 4" thick and then tar/chip.
The lights aren't dimmable as they're just standard low voltage lights, but they don't put off a ton of light. The photo is a bit deceiving making them look brighter than they are. They're just ambient light mostly.
   / Pennsylvania New Home Build Thread. An attempt. #166
The ceiling came out really nice. So did the driveway. I bet you're very happy with all that you have accomplished!!!
   / Pennsylvania New Home Build Thread. An attempt. #167
It's been a while since I have updated as I have been recovering from a back injury for much of the past year. I was able to complete some projects this summer/fall as my back has finally started to really improve. The driveway is finished, we put up a 24' pool, I put in a temporary fire ring/walkway to the pool, built a loft bed for my son, storage shelves in the garage, and now have turned my attention to the basement this winter. Hopefully I can update with pictures again.
I made a video flying around the property this fall where you can see clips of the house/driveway in them as well as the pool/firepit area.
   / Pennsylvania New Home Build Thread. An attempt. #169
Awesome! Sorry to hear about your back; sucks to be laid up when you really want to be working.
Why would you push your strained back to build a "temporary" patio and fire ring?!?!? you're nuts lol.
Don't you need a pole barn? 2023 is the year. :)
   / Pennsylvania New Home Build Thread. An attempt. #170
Sure looks nice there with those lush green pastures and Fall colors!!!!
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
2013 Nissan Juke SUV (A59231)
2013 Nissan Juke...
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
