Anyone have a 17 super duty?
   / Anyone have a 17 super duty? #151
If you look I didn't say it was, just that the FORD mechanic said that was the problem.
DevilDog
   / Anyone have a 17 super duty? #152
DevilDog
I would suggest going back to him and asking how an injection intothe exhaust can ruin valves? Post the answer. I'm curious.
   / Anyone have a 17 super duty? #153
Yep me to and I wonder what the cost for the repair was. I'll post back when I get to talk to him.
DevilDog
   / Anyone have a 17 super duty? #154
DEF is injected in the exhaust stream, no where near the heads or valves.
He needs to find a new mechanic!
   / Anyone have a 17 super duty? #156
Not sure if this relates but it does talk about cracked valves, Check this out. As I said guys don't shoot the messenger,some may not like what others have had troubles with but it is what it is, whether it be Ford dodge Chevy issues are issues.
DevilDog
[ Ford 6.7 liter diesel failure
A mechanic at a Ford dealership in Az posts interesting you-tube clips.
The 6.7 liter Scorpion engine made in Mexico by Ford has a failure pattern
in the non-waste gated chassis---F 450 and 550.
Multiple exhaust valve fractures in vehicles with as little as 20,000 miles.
apparently Ford is redesigning the head
here are 3 short clips
6.7L ENGINE DAMAGE, - YouTube
6.7L ENGINE/VALVE DAMAGE - YouTube
FORD 6.7L ENGINE DAMAGE(211) - YouTube
jh
/COLOR]
   / Anyone have a 17 super duty? #158
The only way DEF could destroy the valves is if someone put DEF in the diesel fuel. DEF is injected in the exhaust and is never near the engine.
Only saying what Ford mechanic told him but are you a Licensed Ford mechanic?
DevilDog
Ummm, you don't need to be a licensed Ford mechanic to know the general workings of the truck. Do you have to be a Ford tech to check oil? Put fuel in? Geez dude.
   / Anyone have a 17 super duty? #159
So, with your general knowledge of a trucks workings.... You don't see how a malfunctioning DEF system can burn valves the same way a clogged up catalytic converter does a gas motor?
   / Anyone have a 17 super duty? #160
If too much DEF is injected and it causes issues with the DPF regen process, bad things happen. Could it wreck exhaust valves? Maybe.
Service Truck (A59230)
2001 CATERPILLAR CB-634C SMOOTH DBL DRUM ROLLER (A60429)
2001 CATERPILLAR...
LOT LOCATIONS (A59575)
2022 Vermeer 573 (A55973)
2022 Vermeer 573...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
2012 Peterbilt 389 Semi (A59814)
2012 Peterbilt 389...
