B2920 hydrostatic transmission
   / B2920 hydrostatic transmission #1
gjock
watertown, New York
Kubota B2920
I traded in my bx2660 for a b2920. The transmission vibrates and rattles a lot more than my bx. Anyone else find the b2920 hydro rough compared to a bx? The fluid levels are fine. I havent talked to dealer yet, just wanted some feedback from actual tractor user first.
Thanks,
Greg
   / B2920 hydrostatic transmission #2
I recently traded a BX2360 in on a new B2620 and found the trans to be noisier than the BX when pulling hard,like going up a steep hill.I mentioned it to the dealer and all he said was to keep the revs up.I run it around 2500 when mowing so there isn't a lot of room to increase rpm's.I now have about 25 hours on it and it doesn't seem as bad.Either it is getting better or I am just getting used to it.I seem to recall reading where someone else said their B tractor got less noisy with increased usage.I am hoping after the first fluid and filter it will be better or I just won't notice it anymore.
I notice it most when mowing up a steep hill also.
thanks
   / B2920 hydrostatic transmission #4
I traded a B2320 and BX25 to a B2620 FEL BH a few months ago and I actually went back to Barlows to try another new B2620 to see if it vibrated like mine. It did so I guess it's normal for that model B. I now have about 28 hours on it and it's either getting better or I'm adjusting to it being like it is. I've had a few different BXs and a few different Bs and my experience is they are all a little different with the BX25 being the smoothest accelerating and running of all and that was right after owning a BX2660 which was different than the BX2350 just before it. I believe my current B2620 is running about like the previous B7800, B3200 and B2320 that I also owned but there were BXs and an L between them. Had the B3200 and BX2660 at the same time and the BXs are quieter and smoother to me. Just my experience as I remember it which can get muddy from time to time.
   / B2920 hydrostatic transmission #5
Having traded my BX2660 for a B2620 a year ago, it now has 112 hours. It (2620) does not make any special noises or vibrations that seem abnormal to me, but I haven't mowed on long steep hills. Now that it is broken in, I mow at 2600-2800 rpm. In doing the 50 hour service, I changed the HST filter only, not the entire SUDT.
   / B2920 hydrostatic transmission #6
I don't notice any shaking or rattling in the tractor or transmission,just an odd noise when pulling hard which seems to be getting better or I don't notice it as much.
   / B2920 hydrostatic transmission #7
There are 3 ranges on the B series.
A little advice from 470+hrs of use so far.
H-Road/high speed low load only
M-Most tasks
L-ground engaging implements
In all ranges if the hydro whines then let up on the pedal to allow the tranny to "downshift". Less flow higher pressure.
It's the opposite of a gas pedal. I was at first stepping on it when things slowed down but I have learned to properly (in my opinion) operate the HST.
   / B2920 hydrostatic transmission #8
Agree with ericher, I keep my 2620 mostly in "m" unless I need some "umph" in 4wd digging into a pile of topsoil or something. I too used my hst pedal as a gas pedal and found that by letting up on the pedal I was actually letting the tractor catch up to the terrain and it was less noisier.
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
LAND PRIDE RCR1260 5' ROTARY MOWER (A59823)
LAND PRIDE RCR1260...
2014 KOMATSU HM400-3 OFF ROAD DUMP TRUCK (A60429)
2014 KOMATSU...
DEUTZ MARATHON...
Deere 310SK (A57148)
Unverferth Roadrunner 536 Head Cart (A59814)
Unverferth...
