Creating a Workshop & Home
/ Creating a Workshop & Home #161
Eddie,
Strong Tie makes a metal bracing that will keep the building square.
I notice that there are no fire breaks in the walls. They would also help a little on the squareness and well as prevent a fire chimney if one ever gets started in the walls.
I lived in earthquake country for around 40 years and since leaving, anything I build is still built with that in mind.
Another thing I have used is a hurricane brace on at least two of the corners. Two 1/2 inch plywood 4x8 sheets nailed into each of the corners, nailed into each stud at 2 inch intervals or closer. It is amazing the extra strength this gives a building.
Your siding will more than likely do what you need but the extra labor and expense really won't be that much.
/ Creating a Workshop & Home #162
</font><font color="blue" class="small">( These angle braces will hold it until my siding gets here. Lesson learned.
)</font>
When I built my home, I used braces like this, but they were laid across the wall and the studs marked. Then, using the circular saw, saw kerfs were made on both the top and bottom that were 1 1/2" deep. Then using a hammer, each piece was hit and broken out of the studs. A quick clean up with a chisel and then the bracing was nailed into the grooves that were made in the studs. This is called "let in bracing". It added great stability to the walls before sheathing and also I have had no plaster cracks from the walls moving in over 25 years. It doesn't take very long and it will keep the walls from racking in the future.
/ Creating a Workshop & Home #163
<font color="blue"> When I built my home, I used braces like this, but they were laid across the wall and the studs marked. Then, using the circular saw, saw kerfs were made on both the top and bottom that were 1 1/2" deep. Then using a hammer, each piece was hit and broken out of the studs. A quick clean up with a chisel and then the bracing was nailed into the grooves that were made in the studs. This is called "let in bracing". </font>
Back in the days before plywood and OSB sheathing, this let-in bracing was a standard practice on new construction. It adds a little bit of extra time, but it might be worth it in Eddie's projects, since the siding is going right on top of the studs...
Thanks guys. I'm aware of the technique, but decided not to use it as part of my experiment with the HardiPanals.
Two other methods that are used in California, where I'm from, are metal strips tied into the sill plate, and metal stips tied into the foundation.
In fact, one of the newer requirements in some earthquake areas of California require the metal straps to be tied into the rebar in the footings and continue to the rafters. I forget the spacing of this, but every four feet sounds about right.
Plus the sheathing must be used on "ALL" exterior walls. Not just the corners.
I've got clear skies for the next week, so I should be good until the panals get here on Tuesday.
Eddie
Andy, Thanks for the diagram, sure nice to see them!
I needed to add a few more bolts to my sill plates and figured it would be easier before the siding went on.
Bosch hammer drill with 1/2 inch Bosch bit. This is a really nice bit!!
My assistant hammered in the bolts.
My other assistant put the washer and nut on.
And then my assistant tightens them down.
It's good to have helpers!!!
My siding arrived yesterday, but I didn't get a chance to start on it until today. Trying to get power ready to be connected.
My girlfriend is doing the house wrap, while I'm hanging the sheets. I only put on the full ones to start, kind of getting my feet wet. In the morning I'm gonna start cutting. /forums/images/graemlins/shocked.gif Not sure what to expect, but I did by their special blade for cutting it, so we'll see.
Eddie
/ Creating a Workshop & Home #170
If you're going to be doing much work with Hardie products, you need this. There's also a more expensive model made by Snapper that has a lifetime guarantee. I have two of the Snapper shears. They work like a dream; no dust, no muss.
Don,
Thanks for the link. I'ver heard about he sheers, but never seen them used. I went to Portor Cable website and found a factory reconditioned one for $50 less.
Doing inside corners seem a bit tricky. The only way I can see to do so would be to round our a wide turn and waste a bunch of material. Especially on door openings.
The saw blade is quick, makes a very clean cut and generates a ton of dust. Wow, it makes some dust!!!!!!!!!!
The only minor disadvantage of the saw blade is the overcut for the inside corners, not counting the dust. /forums/images/graemlins/grin.gif
I can understand there warnings about cutting this stuff indoors. Even with a breeze, I have to position myself on the upwind side before cutting. It's not an issue, but something to deal with.
Picking up a full panal is much more difficult then cutting them!!!
The siding really sets of my cedar posts on the porch for the public bathrooms. I've sort of developed a routine that seems to be working.
The roof arrived a few days early, so I had it set aside until I finished with another project.
My girlfriend is helping with installing it. Some people relax on their weekends, others really know how to party!!!!!!!
/forums/images/graemlins/smile.gif
The section she's standing on is 32 feet long and a bit on the heavy side, not to mention awkward. She said it was the single most dificult thing she's ever done.
Don't tell her, but it only gets worse. /forums/images/graemlins/laugh.gif /forums/images/graemlins/wink.gif
How many girlfriends would do this for a guy? Think I got me a keeper!!!!!!!!
The heat and humidity is the biggest obsticle. We were determined to get this last piece up before hiding in the AC.
After something cold to drink and a nap, we'll get started on the other side. If it doesn't rain, that is.
/ Creating a Workshop & Home #179
Eddie, you're a lucky man. My wife won't hardly stand at the edge of the porch that is 4 foot off the ground. Her helpfulness doesn't seem to be her best attribute from what we can see. no offense intended, Later, Nat
/ Creating a Workshop & Home #180
Eddie, Please do not take offense at this, but will we ever see a photo of the girlfriend with the building in the background. You have one terrific lady there! Projects like my pond we work together on...........and our ideas clash all the time. Today the dear wife helped with a ton of rocks we bought for the pond perimeter. Back to your project, looking GREAT.........
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2004 John Deere 8320 (A63688)
2004 John Deere...
2018 Land Rover 4WD SUV (A61574)
2018 Land Rover...
INSPECTION (A65583)
INSPECTION (A65583)
(4) 235/85R16 TIRES W/ 8 LUG WHEELS (A64281)
(4) 235/85R16...
KMC 3386 (A64119)
KMC 3386 (A64119)
