Has Kubota fixed the leaking front axel on the L series?
   / Has Kubota fixed the leaking front axel on the L series? #1
bilrus61
Platinum Member
kubota 4200
One of the issues on the older L series was a oil leak at the front axel hub pivot. I was looking at the new GL series and they seem to have the exact same design. Have they address the seal issure or do the new GLs leak at the axel also? The Deere drivers seem to have the same issue with the 4000 series. Whats with this? I don't think the big row crop tractors have to have the front axel gaskets replaced every few hundered hours so why can't they design a better sealing system for the little tractors? Is it becasue in Japan they don't use loaders and we over stress the front axels with loader work?
   / Has Kubota fixed the leaking front axel on the L series? #2
Which L tractor do you have?
   / Has Kubota fixed the leaking front axel on the L series? #3
Kubota redesigned the upper seal assembly - the axle still looks the same from the outside. I think the problem is reduced - but still occurring in some cases. Search TBN for more posts about front axle seals. There's a thread here with links to several others. If you read it all you'll be an expert. Take care, Dick B
   / Has Kubota fixed the leaking front axel on the L series? #4
My 03 L5030 has never leaked for what it's worth.
I have a L4200 that is 12 years old. Has had a VERY slow leak in the left axel for 3 years. Not any bother really except for making little spots on the concrete. Just every now and then I'll add a little bit of gear oil to top it off till it runs out the check hole.
   / Has Kubota fixed the leaking front axel on the L series? #6
Same here with my '00 L 3710. no biggie. I just check the oil every 6 mos or so. couple of squirts of oil is all it will take.
   / Has Kubota fixed the leaking front axel on the L series? #7
My 2000 L3010 hasn't leaked yet - but i'm watching it
   / Has Kubota fixed the leaking front axel on the L series? #9
I can change the seals on my 2550 in the dark... When they start POURING gear lube I replace them. I do spend quite a bit of time in mud and Cow s--- though.
   / Has Kubota fixed the leaking front axel on the L series? #10
The danger of failed upper pivot seals is that they let water in, corroding the bearings (and floating the oil out). So machines that spend their life outside or work in mud etc. are more likely to eventually need attention.
2024 CASE TV450B SKID STEER (A60429)
2024 CASE TV450B...
2019 KOMATSU D155AX-8 CRAWLER DOZER (A60429)
2019 KOMATSU...
2017 Ram 1500 Pickup Truck, V6, 4X4, Automatic Transmission, 212,570 Miles (A56438)
2017 Ram 1500...
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
2023 Ford F-150 Crew Cab Pickup Truck (A59230)
2023 Ford F-150...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
