Is This Indicative of the 3032E/3038E's Capabilities?
   / Is This Indicative of the 3032E/3038E's Capabilities? #11
Go back to the Kubota forums and wine
Thats pretty immature and does absolutly no good to help the OP out.
Actually, your other post in this thread also does nothing to help him out.
Your opinion is confusing. There is another thread here that shows someone paying less than $19k for a 1026r TLB. last time I checked Kubota's BX25 was no where near the machine for not much price difference.
I dont see what is confusing. I stated MY OPINION. you talking about a BX25 vs 1026 is meaningless since the OP is talking about a 3038.:confused2:
And I can back my opinion up because I just traded a BX25 for a 1026R. Hands down not even in the same league. The Kubota is a much weaker, lighter machine, both in pulling power and hydraulics.
Good for you:thumbsup: But again, he isnt looking for a SCUT. He is looking for a CUT. so your ONE comparison is of no use. And the FACTS speak for themselves. IF you arent brand blind, for similar money, machines that spec better and have more features are out there.
Anyone tractor shopping with blinders on and only looking at one brand is only hurting themselves.
And your BX25 vs 1026 analysis is what is confusing:confused:
You say the kubota is weaker and lighter.....actually, the BX is about 100lbs heavier. I'll give you the hydraulics though, the deere can lift a whopping 14lbs more on the 3ph and 80lbs more on the FEL. Cant seem to find specs on the deere backhoe?? And given that the kubota is 100lbs heavier, if equipped with the same tires, I dont see how it is possible for the deere to out pull the bx.
But again, none of this immature BS really matters. What matters is that the OP gets a tractor he can be happy with. If that turns out to be a deere 3038, so be it. There are pleanty of satisfied 3038 owners out there. It is just my OPINION that more can be had for the money.
   / Is This Indicative of the 3032E/3038E's Capabilities? #12
Wolfman,
I was the guy who wondered about the ability of the E series to keep the wheels from spinning, particularly with the 3038e. I bought the 3038e after doing some experiments with my mom's cab 3320 tractor as far as inflation pressures of her R1s. That tractor is reasonably heavy with the cab--more than 70 percent heavier than either E series machine--yet I could easily get it to spin the rear tires with too much air pressure (>13 psi), and could just as easily make the need for 4wd a rarity by running her rear tires at around 9 - 9.5 psi.
With this information, as well as info from the AG tire manufacturers handbook calling for low tire pressures rather than liquid fill, I bought the 3038e and have run the rear R4s at 8 - 8.5 psi with very few traction issues bushhogging on steep slopes. If you are going to run you tractor for ground engaging work, I would order an E series with R1s and keep those rear tire pressures reasonably low for good traction.
Tim
Excellent point on the air pressure. If you arent doing a lot of hard'n'heavy towing/pulling, lower air pressures help a ton. Not sure what the OP's intentions are, but if a lot of ground engaging tasks or pulling logs are in order, there is no replacement for weight. Either in the form of a heavy machine or ballast. Power is rarly a factor because of the gearing of the machines. We have an older (very low power to weight ratio) backhoe. It is only 2x's the power of the 3038, but about 5x's the weight, yet it is still geared low enough to spin tires without hurting for power. The power only lets you spin them in a higher gear/faster.
If I were looking for a machine to "tread lightly" across soft terrain. A light machine with low air-pressures would be a prime choice. If heavy ground work is a requirement....WEIGHT.
   / Is This Indicative of the 3032E/3038E's Capabilities? #13
you sir like to nit pick, so I'll nit pick too...the reason I responded to you in the first place:
"Becasue there are other machines out there that are better (IMO) for similar money. Deere's are quite pricey for what you get, because green paint is a lot more expensive than other colors if ya know what I mean."
coming in to the JD forums and posting stuff like this you know good and well you're going to stir the pudding, so I say again, you should just stick to the Kubota forums since you obviously like Orange better than Green.
My post was simply to show you that you are incorrect, Green paint is not necessarily more expensive, but premium features for a similar price makes me wonder if maybe that Orange paint isn't awfully expensive.
   / Is This Indicative of the 3032E/3038E's Capabilities? #14
Wow, I assume you must only hang around the JD forum. Mostly because of how you are acting now, and because I dont think we have ever crossed paths before on this forum.
I dont pay no nevermind to what forum I am posting in. I browse "todays posts" or "since my last visit". In fact, I wouldnt care if there were no "individual" forums at all.
Now lets break it down:
Perhaps you dont know what IMO means?
Not trying to stir the pudding. Just trying to inform the OP. Letting him know that he has "quality" choices not limited to deere.
I actually like all tractors. That is why I dont limit myself with blinders. And I give credit where credit is due. There are several times when newbies ask "kubota vs other brand" questions. And there are several times my first recomendation isnt 'bota. And I think I have been around here long enough to frequent whatever fourm I darn well please.
I am not incorrect. You pointed out ONE case where a deere may have costed less. But it is irrelevent to this post. And then you had to get the little dig in on the kubota saying "its not even in the same league, weaker, lighter, etc" when the specs say otherwise. But thats not the point.
The point is: It is no secret that deere is typically higher priced across the board. Sure, there are a few instances where they arent. But I believe 90% of members here will AGREE that deeres typically cost more than the competition. AND AS I SAID BEFORE, nothing against deere. Deere has earned a good reputation and their right to command that premium price. And if your blinders are preventing you from understanding that, I am truly sorry. And it is also no secret amung you deere fans that the 3038 isnt really the "cream of the deere" crop either. Aluminum housing, no backhoe option, non-removable loader, etc.
And BTW, I never once said anything about kubota being better. I left it open. I said there are "other brands" that may offer a better machine for similer money. IE: better value. IMO (that means it is JUST MY OPINION) you can agree to have a different opinion if you want.
   / Is This Indicative of the 3032E/3038E's Capabilities? #15
I skipped over some of the nonsense, but (look at my sig) I do like JD, BUT I'm unbiased enough to know that the L3200's and L3800's are quite nice machines and spec out quite a bit better than the 3038/3032e's of JD. My only gripe if I was getting the Bota' would be the jerky 3ph, other than that, it is a great machine. I too would suggest the OP to look at them, but what you and most others will find is that the JD will actually be around $2000 cheaper than the Kubota and Deere is running an implement special right now, so if your looking for some attachments it will be even more than $2000. Some say the Deere paint may cost you thousands extra, but I've found it to be cheaper than the Kubota's when I've compared quite a few times, so at least in my area, it's far from the truth. Another thing I'd like to point out is if you have a good Kioti dealer, I'd check out a DK40 or DK35. You will find them to be about the same price as Kubota's L32/3800's, but are Kioti's deluxe models and will be a lot nicer overall machines and the specs are incredible and way out perform even the 32/3800's. Just another idea.
Back onto the 3032/3038E's - I'd blame that video on operator error. To have that loader way up there is just stupid and you'll lose traction. Can't tell, but assuming they weren't, if you load those tires and drive it properly, it should work just fine.
   / Is This Indicative of the 3032E/3038E's Capabilities? #16
Agreed. The hitch is very frustrating. But in all honesty, if I had to choose between my L3400 and a 3038, I'd choose the herky-jerky 3400 anyday. Mainly because of the aluminum housings on the deere and the fact that the loader dont come off. I take mine off ALOT when mowing trails back in the woods. MUCH more manuverable.
Those are acutally what I was thinking of when I said "others". A member of our "kubota" section...koua....just traded his 3400 for a DK35. If my 3400 wasnt paid off and I had a good kioti dealer nearby, I'd probabally consider the same thing.
And as we are quickly learning, the pricing is very reagional.
6 years ago, when I was shopping, the deeres were a good bit higher. The gap has obviously closed up a bit. A few fellows I work with BOTH just bought kubotas last year. One got a B2320 and the other a B2920. They were comparing to the deere 2x20's. (we have a kubota dealer and a JD dealer right next door in MT. Vernon Oh). And BOTH went kubota because of a ~1500-2000 difference in price. But overall, I think the prices are competitive. All depends on how much a dealer will "deal". But the bigger the tractors get, I think deere gets more expensive quicker.
I really have no facts to back this up. Just what I have already said. Most of my assumptions are based on members here posting quotes and such when they are shopping. Because I have not shopped the market in over 6 years. And all I can say is that I consistantly see posts to the the tune of "is the deere worth $xxxx more than brand y" from new members. Thats all I'm saying. But no matter what, as I said, You are only hurting yourself if you only shop one brand and one dealer. You will NEVER get the best deal if you are wearing blinders.
   / Is This Indicative of the 3032E/3038E's Capabilities? #17
K0UA is who I was referring to as well. We all use our tractors differently though, you take your loader off a lot, I've NEVER taken my loader off of any of my tractors. Plenty of ups and downs of different machines, so we can't really tell everyone which machine is best for them but to say go try them all and see what you like.
   / Is This Indicative of the 3032E/3038E's Capabilities? #18
Thats the best advice right there. And thats all I honestly try to do, regardless of color. I try not to "bash" any make. Just point out pros and cons of them, thats all. Someone who's primaty task is light landscaping, the light 3038 is probabally a great choice. But if someone wants to do a bunch of loader work and heavy pulling/lifting, it might not be. In the end, it is best to try out and get quotes on similar models from as many brands as they(shoppers) have local dealers for, and they what you like. Because in the end, THEY have to be happy with the machine. What we think is irrelavent.
And you (@2000 posts) have been around here awhile. And I hope you understand that I am not just a "kubota lover in the deere forum bashing deeres". Because that is not my intent. I ALWAYS try to advise that people research "other" makes when only asking about one. Because honestly, just because we know a lot about tractors, most dont. And like myself many moons ago, alot of people have never heard of the likes of kioti, mahindra, et al. And areas like mine, even CNH and Massey dealers are few and far between. And alot of these "new" shoppers have the misconception that a certain "brand" is better than others across the board, and are none-the-wiser.
   / Is This Indicative of the 3032E/3038E's Capabilities? #19
I agree. I don't believe any people come on here just to bash a brand. They are only offering their insight. I came here looking for a new machine myself, and no one knows it all, and that's why we are all here. Spread what we know and learn what we don't.
   / Is This Indicative of the 3032E/3038E's Capabilities? #20
Nice Quote:thumbsup:
17102 (A56859)
17102 (A56859)
UNKONW  SPOOL TRAILER (A58216)
UNKONW SPOOL...
2005 Chevrolet C4500 Altec Bucket Truck (A56858)
2005 Chevrolet...
KUBOTA M125X TRACTOR (A60430)
KUBOTA M125X...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59905)
2018 INTERNATIONAL...
2012 Kenworth T800 T/A Day Cab Truck Tractor (A55973)
2012 Kenworth T800...
