LBrown59
Super Star Member
- Joined
- Oct 27, 2004
- Messages
- 16,904
- Tractor
- 2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
1*The lite IdeaTaiser said:Was dark by the time I got back so I couldn't take pictures. One thing I've heard and agree with is it REALLY DOES needs better lighting.
1* I'll be looking at lighting options soon, speaking of which...
2*Does anybody know how to tell which alternator is installed on the machine?
concerning lights on rops.
1. Use two lights rather than 4 lights. Mount them on a light bar that will swivel the lights up and down. I install the lights on the bar in a manner that will permit the lights to be rotated 360 degrees. The 360 degrees allows you to have light to the rear and front or both to the front or both to the rear.
Use magnets to mount the brackets for the light bar to the top rear edge of the rops instead of on top of the rops or under the top of the rops. Next bolt the ends of the light bar to the brackets with one bolt through each bracket into the bar.
Tighten the bolts just enough to hold the bar in place but loose enough to move it by hand. The swiveling light bar allows:
(A) Allows adjustment of the distance the lights shine out from the tractor.
(B) Gives more clearance above the lights and more head room under them.
(C) Lessens the chance of catching the lights on something overhead.
(D) Allows the lights to flip down if hit rather than breaking them.
(E) You can just flip the lights down to work under low hanging branches instead of having to remove them from the rops. However you still have the option of removing the bar and lights and unplugging the trailer connector.
*Advantages of the 360 degree rotation *
(A) Permits two lights instead of requiring 4 lights, thus reducing current flow.
(B) Lights can be turned both to front or both to rear. Or they can be turned one to front and one to rear. They can also be used for side lighting. Swiveling lights can provide illumination 360 degrees around the tractor.
Adjustment from one position to another is instant by hand. No wrenches or tools required.
A low profile light preferred over high profile lights.
I've been using this system of combining a rotating light bar with swivel mounted lights to install fog and driving lights on my pickups successfully for years.
More thoughts on lights.
Use a dual direction light with a clear lens on both sides that will cast light to the front and rear at the same time.
Thinking about experimenting with a hanging swing light magnetically attached to the cross member of the FEL to illuminate the bucket shadow when using the head lights.
L.B.
I would not disconnect the head lights but would run the extra lights connected to the key on side of the ignition switch and a separate switch in the line between the connection and the lights. You could also use a switch for / on each light if you desire to control each lite separately.
The reason I prefer going through the key switch is because you can't forget to turn the lights off and run the battery down.
I use a 10 AMP Fuse.
2*Note if you use this method you won't have to worry about the alternator.
