My Garage/Shop Heater Install
   / My Garage/Shop Heater Install #261
I carry a circuit analyzer unit with me in my service rig and that’s helped solve many issues over the years. But it does seam strange that the unit didn’t work due to a ground. You would have thought it wouldn’t have even ignited in the first place. And why shut down after first igniting a flame.
DoN’t you just hate computer boards. Remember old days pilot lights. When a water heater could run without electricity.
   / My Garage/Shop Heater Install #262
I find that a bit odd too. The flame sensor circuit would have to be more sensitive than the other circuits involved? But hey, if it works, it works.
Yeah, those days are gone forever. We are almost always better served. Until something like this happens.
   / My Garage/Shop Heater Install #263
Great news! I think we ALL learned something, from following along.
   / My Garage/Shop Heater Install #264
Just in time to keep the humidity low for that new plainer. Have fun.
   / My Garage/Shop Heater Install #265
Mark, even IF you had hired a tech to troubleshoot, there is a good chance he would have gone through the same time consuming trial and error as you did. Good job!
Yes sir... shop at 50% humidity overnight. Currently 68% outside. Heater doing its job! Thanks again for all those that hung with me, provided advice, and encouragement! That was a tough troubleshoot.
This new jointer is so much bigger than my old 6in Delta that I need to get another length of dust collector hose to reach.
   / My Garage/Shop Heater Install #267
and would've charged you accordingly. :shocked:
   / My Garage/Shop Heater Install #268
When is the shop party ?............
Yeah that is the scary part as the intermittent ground was two outlets away from where it is plugged in.
Since my shop time is irregular, I am now thinking of how I could turn on/off the heater from the house or phone maybe. Gonna have to do some research on smart thermostats I suppose.
   / My Garage/Shop Heater Install #271
I have Honeywell WiFi thermos that I like better than the others.
I also have some WiFi power switches and outlets that work great and inexpensive. Not sure though if cutting the power would do the same as a thermostat.
I shouldn't have said 'turn on/off' instead I meant to bump the heat up or back it down to its default programmed setting.
   / My Garage/Shop Heater Install #273
That would never work for me. I’d use the ap to turn off. Worry about it working and walk out to the shop ten minutes later.....
   / My Garage/Shop Heater Install #274
Set it and forget it..............
   / My Garage/Shop Heater Install #275
Yeah; set it at 50 (warm enough to stop condensation) and man up (or wear a warm hoodie like I do) :laughing: ... Steve
   / My Garage/Shop Heater Install #276
He's out there in his underwear polishing his wood..... I meant tool..... u know........ :)
   / My Garage/Shop Heater Install #279
What you mean is that it was the last place you looked.
   / My Garage/Shop Heater Install #280
Me too. I've got up and looked outside toward the shop to make sure I turned the lights off...…..
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61306)
2021 Takeuchi...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
Cummins 6-Cylinder Turbo Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
HUSQVARNA RIDING...
