My Garage/Shop Heater Install
   / My Garage/Shop Heater Install #271
Yeah that is the scary part as the intermittent ground was two outlets away from where it is plugged in.
Since my shop time is irregular, I am now thinking of how I could turn on/off the heater from the house or phone maybe. Gonna have to do some research on smart thermostats I suppose.
I have Honeywell WiFi thermos that I like better than the others.
I also have some WiFi power switches and outlets that work great and inexpensive. Not sure though if cutting the power would do the same as a thermostat.
I shouldn't have said 'turn on/off' instead I meant to bump the heat up or back it down to its default programmed setting.
   / My Garage/Shop Heater Install #273
That would never work for me. I’d use the ap to turn off. Worry about it working and walk out to the shop ten minutes later.....
   / My Garage/Shop Heater Install #274
Set it and forget it..............
   / My Garage/Shop Heater Install #275
Yeah; set it at 50 (warm enough to stop condensation) and man up (or wear a warm hoodie like I do) :laughing: ... Steve
   / My Garage/Shop Heater Install #276
He's out there in his underwear polishing his wood..... I meant tool..... u know........ :)
   / My Garage/Shop Heater Install #279
What you mean is that it was the last place you looked.
   / My Garage/Shop Heater Install #280
Me too. I've got up and looked outside toward the shop to make sure I turned the lights off...…..
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
flatbed trailer 24ft (A56857)
flatbed trailer...
25 TANDEM DUAL GOOSENECK TRAILER (A58214)
25 TANDEM DUAL...
2020 CATERPILLAR 299D3 SKID STEER (A60429)
2020 CATERPILLAR...
Landoll Lowboy Trailer (A56438)
Landoll Lowboy...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
