Septic & Water Softener part II
   / Septic & Water Softener part II #11
have you ever bought bleach that you couldn't "smell"? i did, so i called the company, they said if the bleach is "fresh", it does not smell, as it gets older and weaker, it starts to smell??
i have seen systems that put the chlorene straight into the well, but i have one that runs any time the pump is running, and takes the bleach from a tank and injects it into the water line, but i do put a cup of bleach in my well ever year or so, the well has the rotten egg smell, so i use a sand filter to help with that and take out the iron..then to a water softener.
heehaw
   / Septic & Water Softener part II #12
Liquid bleach and chlorine tablets are 2 different animals. You should be safe putting liquid bleach in your well because I've done the same thing in the past.
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
1449 (A57192)
1449 (A57192)
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
2022 Kubota Z422-54 Zero Turn Mower (A56436)
2022 Kubota...
