tooth bar . again?
/ tooth bar . again? #1
impdaddy
Omaha, Ne
New Holland 1520
thinking about adding a toothbar to my 110 tl loader on a NH 1520. Any idea what these cost? I know many ppl have talked about the Markham bars. any others anyone recommend? I would want a bolt on.
Thanks to all the good TBN members.
/ tooth bar . again? #3
Figure around $300 to your door...Give Mellisa a call:D
/ tooth bar . again? #7
The mounting bars, at least from Markham, have elongated holes. When you drill the holes in your bucket drill to the teeth side of the hole, by doing this you can loosen the bolts, pull the toothbar foward and flip it back in the bucket and not have to completely remove it.
/ tooth bar . again? #8
For the Markham, you'll need to drill 2 holes in the sides of the FEL to attach it with big bolts. Think mine are about 5/8". Wait until you get it. Should be some instructions about where to drill, etc. I had the dealer install mine before I took the tractor home.
If you don't have the proper drill, bit, etc. you can likely just take the bucket itself off in the bed of a pickup and take it to the dealer.
Ralph
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
Atlas Copco Air Compressor & Air Dryer (A62613)
Atlas Copco Air...
VOLVO G720B GRADER (A63569)
VOLVO G720B GRADER...
207277 (A52708)
207277 (A52708)
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
