tooth bar . again?
/ tooth bar . again? #1
impdaddy
Omaha, Ne
New Holland 1520
thinking about adding a toothbar to my 110 tl loader on a NH 1520. Any idea what these cost? I know many ppl have talked about the Markham bars. any others anyone recommend? I would want a bolt on.
Thanks to all the good TBN members.
/ tooth bar . again? #3
Figure around $300 to your door...Give Mellisa a call:D
/ tooth bar . again? #7
The mounting bars, at least from Markham, have elongated holes. When you drill the holes in your bucket drill to the teeth side of the hole, by doing this you can loosen the bolts, pull the toothbar foward and flip it back in the bucket and not have to completely remove it.
/ tooth bar . again? #8
For the Markham, you'll need to drill 2 holes in the sides of the FEL to attach it with big bolts. Think mine are about 5/8". Wait until you get it. Should be some instructions about where to drill, etc. I had the dealer install mine before I took the tractor home.
If you don't have the proper drill, bit, etc. you can likely just take the bucket itself off in the bed of a pickup and take it to the dealer.
Ralph
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
2010 HEIL TOKEN TRAILER (A63569)
2010 HEIL TOKEN...
2022 Kubota MX5400HST (A64047)
2022 Kubota...
2016 Ford Escape SUV (A61569)
2016 Ford Escape...
2025 Wolverine MSG-11-44W 44in Stump Grapple Mini Skid Steer Attachment (A61572)
2025 Wolverine...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
