When you get them the sliding rail type are good, Besides pallets I use them for picking up stumps and brush piles too.
Picking up loose stumps?
Yes, moving to a burn pile.
Sounds like a similar process I went through on deciding on ag tractor with BH or TLB. Thought I decided on L45 until I saw the M59. Mine is going to be $60k with the thumb, front and rear hydraulics, 16"&24" BH buckets, 3pt lift kit, bolt on bucket blade. I think 12-14% is about the best discount anyone is getting. How is yours working out for you so far?
Still waiting on tractor. hoped it would be built by now. right at 30 days out. Family is headed out of town this weekend and would be perfect time to play...i mean work. Dealer gave me 2 day rental on mini x in deal so has bought me some time on jobs.
AWM59, 60k is right on the money. Have your's yet?
can someone tell me what size chains for proper chain and binder for tractor, loader and backhoe. I figure at least 6 sets. Any thoughts?
How are you going to use the m59?
I would use 5/16" grade 70 chains and ratchet binders.
I would also use 5/16 G70 chains and binders. Lowes has a good deal on 5/16 G70 chain with the hooks on it. It comes in a bag. It looks like this but is around $35. Amazon.com: Campbell Chain T0513598 5/16-Inch by 20-Feet Grade 70 Binder Chain: Home Improvement
Depending on how you plan on securing to the trailer ratchet straps with chain ends may work.
2" Chain Extension Ratchet Straps | 2" Chain Lead Tie Down Straps
One of the first things to learn about backhoe/excavator operation is to hold what is under neath the surface suspect. Call 811 before you dig, while they may not locate your own lines such as this one they will find the expensive to repair stuff.
You know we wan't pics of the new tractor when it arrives. Hope Monday works out for you.:thumbsup:
yeah, i should have been more curious as to why the stump woudln't give up. Every other time it had been one last root i needed to cut.
Dig Test had marked the lines. One thing that worked out better than expected was it appeared the gas line ran within a foot of the sewer line all the way to the street. sewer line actually ran at angle away from gas line thank goodness.
