Weed Wiper
   / Weed Wiper #1
Hiltz
Michigan
JD 790
I had some nasty weeds sprout before my clover this fall and I needed a way to get rid of them. I did some searching on the interweb and found farmers having the same problem used a weed wiper. What a cool idea. Further searching I found instructions on how to build your own as ready made units were pricey. I did find a company in Lyon Mississippi called Rosco that sold kits. They supplied the rope assembly, pvc compression fitting, and instructions. All the builder had to do was buy a 3" x 10' pvc pipe, endcap, elbow and cleanout. I had some glue and cleaner. I built my wiper to attach to the forks of my front end loader. It is a little easier driving around fence posts this way and all the weeds get a good wiping. If attached to the rear the tires knock down the weeds and they don't get wiped. Also I am able to "curl" the wiper where the ropes are on the bottom where they really get a full soaking of roundup. The first picture is before wiping and the second photo is after wiping. The second photo was taken 5 days after the wipe and you can see how the weeds are turning brown and the clover is nice and green. weeds 001.jpgweedsalso 002.jpgweeds 002.jpgweeds 005.jpg
   / Weed Wiper #2
That is neat! I need to build one myself. Do you have a link or contact info for Rosco? My farm is about 10 miles from Lyon, MS
   / Weed Wiper #7
After your treated the weeds did the tires transfer the glyphosate to the clover? I found out the hard way after I treated the driveway and ran over the lawn.
   / Weed Wiper
Steve. Sorry I didn't make that clear. Im not sure what % glyphosate it is. I get my Roundup from a real farmer. This is the agricultural grade or commercial grade stuff the farmers buy in 600 gallon units. I don't use much during the year so usually 2 gallons is all I buy for gardens and food plots. Hope this helps.
I take it that you are mixing one part of 41% glyphosate with 2 parts water. Is this correct?
Thanks for any clarification.
Steve
   / Weed Wiper #9
Around here ag grade roundup is 85% active ingredients.
   / Weed Wiper #10
Nice job.
I did something similar using three 5-ft String Wing applicators from Agri Supply
String Wing, 5' Wick Appicator, Chemical Applicator | Agri Supply, 71934, Rope W
I rigged up an attachment gizmo that fits on the 6-ft wide bucket on the Mahindra 5525.
I get the glysophate from Home Depot--41% concentrate with surficant, dilute 3:1.
Compare-N-Save 2.5 gal. Grass and Weed Killer-75325 at The Home Depot
I buy two 2.5 gal jugs at a time since it has to be ordered and shipped from a Louisiana warehouse and HD has free shipping on orders over $75.
   / Weed Wiper
I was concerned about this and discussed it with the guys at Rosco. Its sort of a catch 22 where you attach your wiper. On the front your tires pick it up. If you attach off your 3 point in the rear your tires will knock down the weeds and they will not get wiped. I have been watching the clover in my tractors tracks and it appears the damage from the roundup is minimal.
   / Weed Wiper #12
Has anyone found recommended glyphosate dilution ratios for alternative species when used in weed wipers?
I plan to buy a weed wiper and would like to use the 41% glyphosate that I now use for spot spraying.
I have looked at glyphosate labels and haven't found any guidance.
Steve
   / Weed Wiper #13
Same here--my wiper is front-attached to the FEL bucket and have seen no problem with transfer from the tractor tires to the plants.
Next time I weed wipe, I'll move the wiper to the 3pt hitch and see what happens just as a test run.
   / Weed Wiper
sms. The Ag grade Roundup I purchase is some really potent stuff. When I spray I mix one and one half oz of Roundup to one gallon of water. I would try to find a farmer friend to buy Roudup from. Its not diluted and farmer don't pay anything close to what the box stores charge.
Steve
   / Weed Wiper #15
Looks like you just fill the tube and drive until it's empty. How do you know when that is???? Or, do you rig up something to keep it filled during use?
   / Weed Wiper
I mixed up 3 quarts at first to see how far it would go and found it takes about 1 gallon per acre to use the wiper. This of course would vary on the thickness of your weeds. Also with the dye you can see it on the weeds as you pass. I would simply watch for the dye and every now and then I would stop and unscrew plug and look at level of liquid. The 3" 10 foot tube will hold approx. 3 gallons of liquid. A simple tank could be rigged up to hold more if needed.
   / Weed Wiper
What kind and how much Dye is used??
Knee, Its a dye Tractor Supply sells for this purpose. Instructions are on the bottle but I just put in a couple of squirts.
   / Weed Wiper #19
What kind of weed? It looks like Galinsoga or quick weed. That is one nasty weed.
Galinsoga - Wikipedia, the free encyclopedia
I had to burn it out of my garden, what a timely adventure. Three 30 lb. cylinders of propane and a bunch of beers.
Fred
   / Weed Wiper #20
From the photos posted it looks like this was being used on flat ground. I'd think it wouldn't work on side hills unless 1) you keep the pipe very full or 2) the rope can wick sufficient amount up into the dry section of pipe. Anyone have any experience using such a rig on hilly fields?
Terry
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56438)
2012 MACK Tender...
2017 Ford F-550 4x4 Ext. Cab Mason Dump Truck (A59230)
2017 Ford F-550...
TANK MANIFOLD (A58214)
2021 SANY SY365C9C5K (A58214)
2021 SANY...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
2020 FORD F-150 XL EXTENDED CAB TRUCK (A59823)
2020 FORD F-150 XL...
