Weed Wiper
   / Weed Wiper #1
Hiltz
Michigan
JD 790
I had some nasty weeds sprout before my clover this fall and I needed a way to get rid of them. I did some searching on the interweb and found farmers having the same problem used a weed wiper. What a cool idea. Further searching I found instructions on how to build your own as ready made units were pricey. I did find a company in Lyon Mississippi called Rosco that sold kits. They supplied the rope assembly, pvc compression fitting, and instructions. All the builder had to do was buy a 3" x 10' pvc pipe, endcap, elbow and cleanout. I had some glue and cleaner. I built my wiper to attach to the forks of my front end loader. It is a little easier driving around fence posts this way and all the weeds get a good wiping. If attached to the rear the tires knock down the weeds and they don't get wiped. Also I am able to "curl" the wiper where the ropes are on the bottom where they really get a full soaking of roundup. The first picture is before wiping and the second photo is after wiping. The second photo was taken 5 days after the wipe and you can see how the weeds are turning brown and the clover is nice and green. weeds 001.jpgweedsalso 002.jpgweeds 002.jpgweeds 005.jpg
   / Weed Wiper #2
That is neat! I need to build one myself. Do you have a link or contact info for Rosco? My farm is about 10 miles from Lyon, MS
   / Weed Wiper #7
After your treated the weeds did the tires transfer the glyphosate to the clover? I found out the hard way after I treated the driveway and ran over the lawn.
   / Weed Wiper
Steve. Sorry I didn't make that clear. Im not sure what % glyphosate it is. I get my Roundup from a real farmer. This is the agricultural grade or commercial grade stuff the farmers buy in 600 gallon units. I don't use much during the year so usually 2 gallons is all I buy for gardens and food plots. Hope this helps.
I take it that you are mixing one part of 41% glyphosate with 2 parts water. Is this correct?
Thanks for any clarification.
Steve
   / Weed Wiper #9
Around here ag grade roundup is 85% active ingredients.
   / Weed Wiper #10
Nice job.
I did something similar using three 5-ft String Wing applicators from Agri Supply
String Wing, 5' Wick Appicator, Chemical Applicator | Agri Supply, 71934, Rope W
I rigged up an attachment gizmo that fits on the 6-ft wide bucket on the Mahindra 5525.
I get the glysophate from Home Depot--41% concentrate with surficant, dilute 3:1.
Compare-N-Save 2.5 gal. Grass and Weed Killer-75325 at The Home Depot
I buy two 2.5 gal jugs at a time since it has to be ordered and shipped from a Louisiana warehouse and HD has free shipping on orders over $75.
2025 IRGC40 Mini 3 60v Electric Tricycle (A56859)
2025 IRGC40 Mini 3...
2015 12ft Towable Hot Pressure Washer Trailer (A56857)
2015 12ft Towable...
SDLanch 12'x20' High-End Carport (A57149)
SDLanch 12'x20'...
UNUSED FUTURE FT36C STAND ON SKID STEER (A58375)
UNUSED FUTURE...
19008 (A56859)
19008 (A56859)
Mccormick Hammer Mill (A57454)
Mccormick Hammer...
