Weed Wiper
   / Weed Wiper #1
Hiltz
Michigan
JD 790
I had some nasty weeds sprout before my clover this fall and I needed a way to get rid of them. I did some searching on the interweb and found farmers having the same problem used a weed wiper. What a cool idea. Further searching I found instructions on how to build your own as ready made units were pricey. I did find a company in Lyon Mississippi called Rosco that sold kits. They supplied the rope assembly, pvc compression fitting, and instructions. All the builder had to do was buy a 3" x 10' pvc pipe, endcap, elbow and cleanout. I had some glue and cleaner. I built my wiper to attach to the forks of my front end loader. It is a little easier driving around fence posts this way and all the weeds get a good wiping. If attached to the rear the tires knock down the weeds and they don't get wiped. Also I am able to "curl" the wiper where the ropes are on the bottom where they really get a full soaking of roundup. The first picture is before wiping and the second photo is after wiping. The second photo was taken 5 days after the wipe and you can see how the weeds are turning brown and the clover is nice and green. weeds 001.jpgweedsalso 002.jpgweeds 002.jpgweeds 005.jpg
   / Weed Wiper #2
That is neat! I need to build one myself. Do you have a link or contact info for Rosco? My farm is about 10 miles from Lyon, MS
   / Weed Wiper #7
After your treated the weeds did the tires transfer the glyphosate to the clover? I found out the hard way after I treated the driveway and ran over the lawn.
   / Weed Wiper
Steve. Sorry I didn't make that clear. Im not sure what % glyphosate it is. I get my Roundup from a real farmer. This is the agricultural grade or commercial grade stuff the farmers buy in 600 gallon units. I don't use much during the year so usually 2 gallons is all I buy for gardens and food plots. Hope this helps.
I take it that you are mixing one part of 41% glyphosate with 2 parts water. Is this correct?
Thanks for any clarification.
Steve
   / Weed Wiper #9
Around here ag grade roundup is 85% active ingredients.
   / Weed Wiper #10
Nice job.
I did something similar using three 5-ft String Wing applicators from Agri Supply
String Wing, 5' Wick Appicator, Chemical Applicator | Agri Supply, 71934, Rope W
I rigged up an attachment gizmo that fits on the 6-ft wide bucket on the Mahindra 5525.
I get the glysophate from Home Depot--41% concentrate with surficant, dilute 3:1.
Compare-N-Save 2.5 gal. Grass and Weed Killer-75325 at The Home Depot
I buy two 2.5 gal jugs at a time since it has to be ordered and shipped from a Louisiana warehouse and HD has free shipping on orders over $75.
24in excavator tooth bucket (A56436)
24in excavator...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A56436)
Gleaner N630 Corn...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
2461 (A58376)
2461 (A58376)
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
