Welcome to my Nightmare!!!!
   / Welcome to my Nightmare!!!!
Here's an action shot Steph took of me working on those sleeves.
Eddie
Another action shot, only this time I'm looking for the bolt after if fell under the dozer. Good thing I put it on ramps, cause the extra room has made a HUGE difference!!!
Eddie
Well, my contraption works!! /forums/images/graemlins/grin.gif
And the mystery of what a wet sleeve looks like is now solved. I aslo now understand what they mean by the term "wet" sleeve. It's because the sleeve is surrounded by water in the block!!!
Don't laugh, I'm coming at this totally blind. /forums/images/graemlins/confused.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/grin.gif
Eddie
   / Welcome to my Nightmare!!!! #74
It's amazing how many "specialized" tools you can make yourself with a little ingenuity, a little metal, and a welding rig.
   / Welcome to my Nightmare!!!! #75
Eddie:
I have rebuilt gas engines before, but never a diesel, and never a sleeved one, so this question is just out of curiosity. (I did rebuld a rotary-engine Mazda way back when.)
What seals the joint betweeen the block and the sleeve?
I followed the part about cooling the sleeve and heating the block so that thermal expansion would allow the sleeve to slip in easily and then expand to fit, but the difference in size is going to be small.
If there is any rust, scale or other corruption in the sealing area between the sleeve and the sealing surface in the block will there be trouble?
Does anyone with experience care to comment?
Dave
P.S. I want to see a picture of this thing working after all this...
   / Welcome to my Nightmare!!!! #76
My father in law was a Int'l Harvester truck dealer over 40 years, One thing all his mechanics did was the new replacement sleeves were put into a freezer two days before installing. This, made them almost "drop" back in.. Of course these are the old timer mechanics, the way things were done then,,
   / Welcome to my Nightmare!!!! #77
I knew Steph would get involved here at some point, just thought she'd have a wrench in her hand /forums/images/graemlins/grin.gif..
Eddie, maybe you can sell your design for a couple hundred bucks...Its amazing what one can do if he really thinks about it..
Curly, I'm in a similar boat as far as actually doing one of these.. But, to my knowledge, its just a metal to metal connection(seal).. The minute size change of metal under different temps is plenty to create this seal. This is also part of the reason you need to add an anti cavitation additive to your coolant on a regular basis.. It reduces the scale, electrolisys and metal transfer that would cause a leak.. Like I said, I've never actually done one, but thats my understanding of it..
   / Welcome to my Nightmare!!!! #78
Oh, Eddie, BTW,
The diesel fuel in the oil thing is to "clean" things up a bit.. The issue here is that you wont have a dirty engine when youre done.. The bearings will be relatively dry when you first go to cranking on it.. You want real oil there not a thinned one.. If you had an engine with a gazzilion hrs on it and the oil looked nasty(or maybe HEUI injectors that were sticking) a quart of diesel fuel would help clean it out.. Some of you guys may have heard of ATF in a gass burner or even Mytery Oil, same thinking..
   / Welcome to my Nightmare!!!! #79
Not only heard of it, but I've used ATF and even kerosene to flush an engine; mixed with oil of course.
   / Welcome to my Nightmare!!!! #80
The difference a little heat makes can best be understood when replacing the starter ring on the flyweel of a standard transmission motor.
You can pound and press until the cows come home and it won't go on. But if you take a torch and gently heat up the ring, not to red, just hot, that pupply will literally fall on and after the temperatures have equalized between the ring and flywheel you can't remove the ring.
One of the images I have in my mind is Eddie at Lowes explaining why he doesn't want the freezer after just a couple of days use. /forums/images/graemlins/grin.gif
Look at the size of those sleeves and then imagine trying to put six of them in your freezer. Might be time for a large ice chest and some dry ice. /forums/images/graemlins/blush.gif
1969 CHEVROLET C10 SHORTBED PICKUP (A54607)
1969 CHEVROLET C10...
2012 Mack GU713 T/A Gardner Denver Kill Truck (A52377)
2012 Mack GU713...
2019 Kia Soul SUV (A53424)
2019 Kia Soul SUV...
2003 Pierce Spartan Pumper Fire Truck (A51692)
2003 Pierce...
2018 SkyJack SJ1056TH 10,000LB 4x4 Rough Terrain Telehandler (A52377)
2018 SkyJack...
2017 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A54607)
2017 FREIGHTLINER...
