What's in your Ballast Box?
   / What's in your Ballast Box? #11
Re: What\'s in your Ballast Box?
That's nothing.. I've got you beat in the ugly dept.. er /forums/images/graemlins/blush.gif My box blade has yer boxblade beat in the ugly dept!
As you mentioned.. having a non tool on back sometimes is a handicap. I've been prepping for some road grading using my ford 66 with fel... needed a box blade on it.. but my box is light/med duty and not heavy enough as a good counterweight.. deffinately not as heavy as that concrete plug I made.
After looking around, I grabbed 3 empty plastic cat litter containers ( roughly 5 gallon bucket size.. though more rectangular than cylindrical ) Filled em with ..you guessed it.. mostly concrete, though did add some scrap metal bits.., and left a metal loop sticking out the top as a chain loop or tie down. Those weights set perfectly on the box blade angling forward from back edge, resting on the tooth holder.
I figure all together , box blade and weights, it weighs at least as much as my ballst tub.. and should give me lots more options when leveling some driveways.. etc.
I'llpost some pics the first time I actually hitch it up.
Soundguy
   / What's in your Ballast Box? #12
The original poster is looking at a sub-CUT so size may be an issue. I specificly chose a ballast box due to size. Any thing else hanging off of the 3 pt hitch would stick out farther than the ballast box reducing the manueverability of my sub-CUT.
I think of the ballast box as a car trunk. I don't even realize it's there but it sure is handy when I need it. Besides hauling the aforementioned firewood it also hauls tools and supplies. The chainsaw, helmet, chaps, gas, oil, a water jug, etc all fit nicely when I am cutting firewood.
Phil
   / What's in your Ballast Box? #13
</font><font color="blue" class="small">( Any thing else hanging off of the 3 pt hitch would stick out farther than the ballast box reducing the manueverability of my sub-CUT.
)</font>
Phil,
I feel the same way. I did not initially get a ballast box because I planned to use my tiller for ballast. I quickly found out that the tiller limited manueverability especially in the winter when I was clearing my driveway. If you have a lot of room work, an implement as ballast may be a better solution. But if you want maximum manueverability the ballast box is best way to go.
John
   / What's in your Ballast Box? #14
Darn, you guys must be working in some really tight spaces. Personally, I do what Jinman does and for the same reason. I use the box blade and stack additional weight (concrete blocks usually) on top of it if I need it. It takes a little more swing room but not much.
   / What's in your Ballast Box? #15
I go to our town dump and snag the discarded weights from exercised machines that get dumped. Got about 700 lbs at this point, various shapes and sizes. I like the cast iron ones best, the palstic coated ones can crack their coatings when it gets freezing and wet. Free. /forums/images/graemlins/grin.gif You can always fit them in the ballast box and they are easy to take out 1x1.
   / What's in your Ballast Box? #16
If you saw John Day try to move around his place with his box blade mounted on the 3PH, you would know why a weight box works so well. /forums/images/graemlins/grin.gif
Most of the time I use my tractor for FEL work. Do not need any big attachment on the back, just waiting to wack into something. /forums/images/graemlins/frown.gif
Wish I had all the open area you have down there in TX. /forums/images/graemlins/grin.gif
   / What's in your Ballast Box? #17
</font><font color="blue" class="small">( If you saw John Day try to move around his place with his box blade mounted on the 3PH, you would know why a weight box works so well.
Most of the time I use my tractor for FEL work. Do not need any big attachment on the back, just waiting to wack into something. )</font>
Your ballast box is also a handy carry-all and hitch. Kubota made a nice dual-purpose implement. Now, if it had a chute you could pop open on the back, it just might work good for hauling wet concrete like Harvey does with his special bucket for Iris. /forums/images/graemlins/cool.gif
   / What's in your Ballast Box? #18
I better clarify that I put the receiver hitch on weight box. Not <font color="orange">Kubota </font>. /forums/images/graemlins/cool.gif
   / What's in your Ballast Box? #19
Dont forget to buy a dolly to move the box around. I filled mine with concrete and "wrote" the weight added on the surface.
   / What's in your Ballast Box? #20
I made Soundguy's ballast suggestion and love it.
Have you all noticed that the front end tends to want to pop up when you are floating the loader while grading/digging moving forward with the ballast on? I only take a thin slice of soil on the bush trails and it really makes a nice, level job of things (no rocks here), but I'm wondering if I should be adding ballast to the front end too?
Thanks
PS I will post this as a separate thread if you wish -- am not trying to change the thread.
PPS on second thought, I will post this as a separate question
Shawn
2018 VOLVO EC480EL EXCAVATOR (A60429)
2018 VOLVO EC480EL...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
2017 Genie GTH-5519 (A53317)
2017 Genie...
2012 International Prostar (A56438)
2012 International...
2018 Chevy Silverado 1500 4X4 (A56438)
2018 Chevy...
