Ford 2_138 4.40 star(s) (18)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Ford 2_138.
25-50 HP Tractors
About the Ford 2_138
Ford 2_138 Discussions (366)
Here are the most recent 2_138 topics from our community.
  1. R
    Help with Ford 1700 headlight.
    Hi All! Noticed I had a headlight out. I rebuilt my grill over a decade ago, and I remembered the bezel was held on by an odd spring clip. I managed to pop the bezel off, but can’t figure out...
  2. R
    Ford 1700 not charging
    Hi All! First off, forgive my long-winded ramble. Just trying to give as much info as I can. I went out to do my pre-snowstorm check on the Ford 1700, and discovered the battery was dead. It...
  3. N
    Help Ford 1700 757 Backhoe Seals
    I need help sourcing cylinder seals to rebuild all 3 boom cylinders, Can't find replacement seals online. Any suggestions are appreciated.
  4. F
    Ford 1700 Starting Problem
    Hello. Have a Ford 1700. Not in any way, shape or form a mechanic but thanks to this forum have kept it going 15 years now. Have a new issue which has me stumped. Unable to start tractor. It...
  5. G
    Ford 1700 - 3 point lift control loose on the way up
    Hi! I have an old Ford 1700. Recently, the control arm for the 3pt lift has been "slipping" up. Messing around with it, it goes down with resistance, but when I pull on it, it moves pretty...
  6. S
    ford 1700 won't move and stalls when clutch is released
    Hello, Hello, i have you ever ran across s 1979 ford 1700 will not move and stalls when clutch is released, I was connecting to an when I tried to take off, the tractor would not move. When I let...
  7. S
    Ford 1700 vs Ford 1510
    Hey guys, first post. I've been googling and searching this for months and I'm still at a loss, so finally decided to just pose the question outright and see what folks more...
  8. J
    Snow got into my air (oil) filter on '83 Ford 1700
    And how did the snow get in there, you ask??? Well, because I'm a STOOPID - that's how. Battery was dead so I went to change it - took air/oil filter vent stack off to open hood ....... and...
  9. Hexa Fox
    Ford 1700 to Purchase or Pass?
    Hey guys, So I did create a post about this before. At that time I did not have all information. So there is a neighbor that lives nearby that said he may be interested in selling his Ford 1700...
  10. Nerraw117
    Ford 1700 steering
    Anyone know of a steering assist kit or power steering kit for a 1700? I’m aware of the Jackson but $1900 is a hard pill to swallow. My new box that I got from kumar bros last 4 months and broke.
  11. J
    Ford 1700 just quit while brush hogging
    Was out doing my normal brush hogging, all going fine/normal, when I went over a section of raise up dirt that bogged down the machine. I assumed it was just a small mound and after restarting...
  12. T
    New owner of old Ford 1700 - questions
    I recently picked up a 1980 Ford 1700 2wd with nearly 3300 hours to mess around with. The sound of the 2-cyl diesel is unique! It seem to run and shift fine. Some questions: 1. The turnbuckles on...
  13. woody
    1980 Ford 1700 radiator screen
    the radiator screen on my 1980 Ford 1700 is rotten and trying to pry the metal frame a part to just replace the screen is not working. I have found a couple of complete screens on line but at 120...
  14. D
    Ford 1700 Diff lock lever is stuck
    I've just inherited a 1980 Ford 1700 4WD and I have a couple of issues that I'm hoping someone can help me with. This one is about the diff lock. I just noticed that the lever for engaging the...
  15. D
    Ford 1700 cooling issues
    I've just inherited a 1980 Ford 1700 4WD and I have a couple of issues that I'm hoping someone can help me with. The first is the cooling system. It seemed to be fine when I was plowing snow, but...
  16. J
    Ford 1700 step plate help
    Anyone have experience with replacing rubber mounts/spacers for the step plates; or have suggestions on alternatives to secure the step plates. Will appreciate any thoughts.
  17. jdrm
    Ford 1700 backhoe
    Can anyone tell me the difference between a Ford 758 758a 758b and 758c backhoes attachments. Thanks
  18. Hexa Fox
    Ford 1210 vs Ford 1700
    Hey guys, So this community has been awesome so far and things are getting more complicated. As some of you may know my neighbor just gifted me an old 2WD Ford 1210 and I am deciding what to do...
  19. F
    Ford 1700 Wheel Question
    Hi, Very inexperienced old tractor owner. Trying to get the rim off the center piece of the rear wheel to replace it. I am not familiar with the kind of nuts holding the piece on. I know it's...
  20. F
    Ford 1700 won't start
    Ford 1700 tractor stopped I drained gas put new cleaned glow plugs turns over won't start notice no smoke not coming out of stack at all...can ya help me out.
[ad placeholder]
User Reviews (18)
Read what TractorByNet members think about the Ford 2_138 Subcompact Tractor
5
44 %
4
50 %
3
6 %
2
0 %
1
0 %
5.00 star(s)
terraced gardens
2_138 Ford
Best Small Tractor For My Situation
Model Year: 1980
There were several things that I was in the market for. I travel 3 miles from one farm to the other so wanted a good travel speed. This one goes about 4 mph faster than a lot of the compact tractors. I also wanted an adjustable front axle and adjustable rear wheels so it had to be two wheel drive and again, there were very few models in this HP range that had this. I also wanted a great transmission with nicely stepped gear ranges. I don't think anyone else has a tranny like this. Start in low range and go through the 3 gears, step to 2nd range and go through the 3 gears, all the way to the top gear and there is no overlapping. Love it! I have had to do several repairs and have found parts easily by searching on the net. I have run one of the 1710 models and it has a 3 cylinder engine instead of the 2 cylinder. That is a much smoother engine and starts much easier. Have to use the glow plugs almost all the time unless the engine is warm from running.
Pros: Dependable, easy on fuel and very versatile.
Cons: Hard to start, have to use the glow plugs.
5.00 star(s)
lira1810
2_138 Ford
Very Good Tractor the Best
Model Year: 1979
Good tractor strong enough uni problem was the hydraulic 3 PTOS Q I put hydraulic direction and is now slower.
Pros: Good tractor strong enough.
Cons: See above.
5.00 star(s)
havehope
2_138 Ford
Little Blue
Model Year: 0
Great little all around machine for small farm/garden. Added bucket which is more helpful than anything else.
Pros: Simple operation.
Cons: When the ground is wet it would be nice to have 4 wheel drive.
5.00 star(s)
drlabrador
2_138 Ford
Property Maintenance Equipment
Model Year: 1978
Machine needs minimal maintenance.
Pros: Machine built to last long.
Cons: Bulky for a compact tractor.
4.00 star(s)
Anonymous Poster
2_138 Ford
Ford 1700 Small But Sturdy
Model Year: 1981
Ford 1700's, like my FORD 600, are relatively small but sturdy...lil' tractors and I would argue with anyone about the 1700 being a gas guzzler or having lift problems. This compact tractor does some really big work on hardly any diesel and I'd recommend this Japanese built Ford to anyone. It uses all of the equipment that my larger 600 uses and seems to handle it all quite well....superbly on some counts. My only complaint is the size in which the cockpit tightly envelopes the operator and I don't particularly care for the balance when considering how certain grades of ground causes the tractor to be back-heavy. Even with several heavy weights, any type of load at any sharp grade will cause it to do a wheely. Great tractor though....I just wish it had been built by Americans. Sorry that I have yet to take some photos (other than what I put in temporarily of my Ford 600 etc).
Pros: Tough, durable, maneuverable, cheap to operate.
Cons: Light, rare/expensive parts to some degree and not open enough for a big operator.
Photo Uploads:
5.00 star(s)
Jeremy Jon
2_138 Ford
Steering Box is Weak
Model Year: 1982
This model tractor seems to suffer from a weak manual steering gear box. I knew this from other online reviews prior to purchase. As it turns out, the steering shaft has integral bearing races (both upper and lower bearings). When you replace the bearings, all you are replacing is the balls with open cage assembly unless you buy a new steering shaft and or new gearbox, which forms the opposite side of the bearing's race. To me, this is a design flaw in that you can't simply replace a bearing as a sealed unit, gaining new races in the process. Unfortunately, this "design flaw" is directly proportionate to the unit's reliability. the issue seems to be worn race(s) on the steering shaft over time. The best way to check a 1700 before you buy is to watch the steering wheel closely. As you turn from side to side with the wheel, watch for the wheel to raise and lower slightly in relation to the dash. Any up or down movement will indicate wear in the steering at the bearing(s). Aside from this issue. The tractor has plenty of capability!
Pros: Price, fuel consumption, capability, it's a workhorse.
Cons: Steering gearbox/bearing issue making reliability suffer.
4.00 star(s)
billtaylor01
2_138 Ford
Ford 1700
Model Year: 1980
Only problems I have had is: 1. Hydraulics seem to get water in it and freeze up in the winter 2. Pre august 31 1980 machines have weak front 4 wd axles and the are known to break which has happened to me and its a very expensive fix. Other than that great working little tractor.
Pros: Small, versatile great for small acreage.
Cons: 1979 Aug. 1980 weak 4 wd front axle. Parts expensive hard to find.
4.00 star(s)
The machinist
2_138 Ford
Works Hard Easy on Fuel
Model Year: 1981
First tractor ever. First thing I did was buy the manual from Jensales so there are no mysteries when a maintenance issue arises. I learned that water will leak into the transmission/hydraulic system and freeze up the components. Built a custom backhoe and dug a 5'x 200' trench and it only burned about $10 in fuel. Engine starts all the time, great unit, keeps your arms in shape when working with the loader full. Maintain the fuel system (filter and injector pump) and lots of grease and oil, the cheapest maintenance.
Pros: Always starts, burns little fuel, nimble enough to get anywhere.
Cons: Keep it out of the rain or tarp it, no power steering, trans PTO.
4.00 star(s)
WoodyK
2_138 Ford
Ford 1700 - Works Good
Model Year: 1985
A good basic tractor. No built-in hydraulics or front end loader. Bought it from a friend. It's a pain when you run out of diesel fuel---you have to take off the fuel injector lines to bleed it.
Pros: Solid construction.
Cons: Ugly when you run out of fuel. No hydraulics.
4.00 star(s)
tonyinrecovery
2_138 Ford
Still Learning
Model Year: 1980
Seems to be a good medium duty tractor. I have been been leveling off some of my yard mostly front end loader work, I am a beginner with this being my first tractor, Love the 4 wheel drive, it really adds to the ability to skim the high spots off with the loader bucket.
Pros: Starts good, works hard, services easy.
Cons: No power steering.
5.00 star(s)
bridgstone67
2_138 Ford
Ford 1700
Model Year: 1983
I got this little 1700 about 1 1/2yrs ago, it had been very badly abused and didn't run well at all. All the tires were full of liquid which I drained out. I lots rather spin than brake. Had water in the oil an no power. I knew it had serious problems when I got it. I rebuilt the engine, the head had been cracked before and was cracked again, cost almost $400 to repair the head. I got it back together and it does fine. Had to get used to the power though, I was used to the power of my Allis Chalmers 5050. Overall I think it's a nice little tractor if you can get by with one of it's size, It would never take the plac a bigger tractor. That was the problem with it when I got it. Someone tried to make it work like a big tractor, it may work for a while but it's gonna brake.
Pros: Small and easy to get around with for small jobs.
Cons: No cons really.
Photo Uploads:
5.00 star(s)
jrgoody
2_138 Ford
Love this Tractor
Model Year: 1980
Original 1700. 1408 hours as of 2012. 4x4. 770 Loader. What a wonderful item. Built like the larger work horses. 540rpm rear PTO. Would recommend this unit to anyone.
Pros: 2cyl diesel always starts.
Cons: Loader limit is about 500-600 lbs in reality.
Photo Uploads:
4.00 star(s)
mbland06
2_138 Ford
F 1700 Ford
Model Year: 0
First tractor, great price, have a few things to update/repair, but love my new toy!!
Pros: Strong motor.
Cons: Didn't have fenders or front end loader.
5.00 star(s)
ridger
2_138 Ford
Owner
Model Year: 1979
I bought this tractor new over 30 yrs ago and can't say anything bad.
Pros: Dependability.
Cons: None.
4.00 star(s)
leiman1
2_138 Ford
Owner of Ford 1700
Model Year: 1980
For an older tractor it is a great unit.
Pros: Runs great w/ excellent power.
Cons: Does nor appear to have a live PTO.
4.00 star(s)
Anonymous Poster
2_138 Ford
Ford 1700
Model Year: 1979
I bought my Ford 1700 from a guy in our organization. Being first time Tractor user I had very little experience with it. I’m mechanically inclined and okay with wrenching and I was extremely pleased to see how easy it is to maintain this tractor. My Ford 1700 is a basic machine and does not have much fancy options as far as front end loader, live PTO but does have live hydraulics which is great. It is light and nimble @ 2500 lbs and can get in to tight areas. I consider it to be one of the best investments I made. I paid $3100 for it with actual 900 hrs on the proof meter. It has been stored in the barn or garage and has some paint fading but nothing bad, has some surface rust but it’ll out live me as the sheet metal is thick and good quality. Fit and finish and casting look excellent and appears to have excellent metallurgy. I have done much work on it and they were all relatively easy and painless. I have gone thru the whole hyd system, including hyd pump overhaul, hyd cylinder seal and had no issues so far with the parts from NH dealer. All the maintenance I have done to it cost me about$250 and I did a lot on it. I know the major engine parts will be pricey. I trust I can maintain this 1700 for a long time if I give it a bit of TLC. The consumables are easy to find and replace. I don’t expect engine overhaul as long as oil and radiator is kept up before 4000 hrs, probably will not be around to do it. It has been a $5500 investment with the implements that I bought and made and could not be happier. I’d be happy as a lark if it had live PTO and FEL.
Pros: Great little tractor
Cons: Missing live pto and fel
Photo Uploads:
3.00 star(s)
Mark Holaway
2_138 Ford
Ford 1700
Model Year: 1976
Tough little tractor once the flaws of design are fixed. Had to build new kingpin steering arms (4x4) as I was unable to find a used one anywhere. They were designed too light and are prone to breaking. I needed a good compact 4x4 tractor and did not want to spend the money on a newer model. Great value for the buck.
Pros: good power for the size
Cons: Hard to find parts
Photo Uploads:
4.00 star(s)
kmudpup
2_138 Ford
Ford 1700
Model Year: 1979
Bought this used and it has a bucket loader. This is a very powerful small tractor that has tons of time on it (though hour meter doesn't work). It's a diesel and it just has tons of power, 12 speeds and lots more. Mine is 2 wheel drive (the only disadvantage...if you have slick or muddy soil I strongly suggest the 4 wheel drive version) but overall these can be bought at a good price and the diesel makes it ideal to run economically at home or on a small farm.
Pros: Powerful, cheap to operate, reliable
Cons: Would be better to have 4 wheel drive..otherwise no negatives
Photo Uploads:
[ad placeholder]
Ford 2_138 Owner Pages
View owner pages to see photos, customization and comments about member-owner Ford 2_138s
Ford 2_138 Community Rankings
#471 user rating of 2355 25-50 HP Tractors items
#595 Viewed of 2355 25-50 HP Tractors items
#9 discussed of 2355 25-50 HP Tractors items
#1202 user rating of 19625 items overall
#1747 Viewed of 19625 items overall
#21 discussed of 19625 items overall
#11 Ranking of Most-OwnerPages in 19625 items overall
