Mahindra 6000_3 4.60 star(s) (11)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Mahindra 6000_3.
50-100 HP Tractors
About the Mahindra 6000_3
Mahindra 6000_3 Discussions (67)
Here are the most recent 6000_3 topics from our community.
  1. 5
    Mahindra 6000 radiator drain valve and block drain..
    Does the drain valve screw in and out, or does it just pull out. I have operator and service manuals, and neither tell how to open it. The manuals just say to open. It also says there is a...
  2. sfoms
    ML260 on a 2005 Mahindra 6000di
    Hello All! I am new here and relatively new to tractors. We have a 2005 Mahindra 6000di with a ML260 front end loader/bucket. Recently the bucket started to slow when lowering. Raises, curls, and...
  3. A
    Mahindra 6000 PTO won't engage
    For starters, the only implement I generally run off the PTO is a 6' shredder. We've owned this 6000 for several years (purchased used). During that time, the PTO has occasionally disengaged...
  4. S
    Kubota M series VS, Mahindra 6000 series
    Greetings, My father in law is looking for a new tractor for his farm 160 acres in upstate NY. He currently has a small Yanmar LX590 ( I believe) which is too small for the task of lifting large...
  5. B
    Mahindra 6000 4WD....what's that lever for???/
    This sounds crazy even to me...I've had this 6000 since new in early 2003....as you sit in the seat on the left side down and back from the "power beyond" lever is a second lever that goes into...
  6. R
    Mahindra Power Loss - Mahindra 6000 2wd
    So this may be long thread but I need help diagnosing a problem and a little backstory may help. I poked a hole in radiator and didn't realize it until tractor overheated (temp gauge not...
  7. M
    Mahindra 6000 Hydraulic suction strainer removal
    I'm changing the hydraulic fluid and I'm having trouble removing the suction strainer pipe. I've removed the retaining tab and I'm able to rotate the pipe but I can't pull it out. What could be...
  8. J
    Mahindra 6000 - 03' - Starter Question
    Hello All, I recently purchased a Mahindra 6000 and love the tractor, but am having starter issues. When I got it, it was having a few issues starting. I bought a new battery, and it would...
  9. B
    Mahindra 6000 starter motor
    Does anyone know who manufactured the older (around '03) starter motors for the Mahindra "00" series tractors? Mine works fine if its above 40degrees, but doesn't quite have the guts to turn it...
  10. O
    Mahindra 6000 4WD will not start. NO POWER
    I have been clearing large trees from my wooded areas. A couple days ago when I came back from lunch the tractor would not start. When I turn the starter switch there is no power to the dash...
  11. O
    No power to start my Mahindra 6000 4WD
    Recently clearing woods and stopped for an hour break. When I came back there was no power to the switch. Gages are dead, no starter click even. I have looked for a few hours on the forum but...
  12. drdoolittle
    Adding aux hydraulics to a Mahindra 6000 2wd
    Question for the group - if I were to purchase an aux hyrdaulic kit from a dealer, how difficult would it be to do the install myself? I'm pretty comfortable twisting wrenches, etc., and would...
  13. Q
    Mahindra 6000 2 wd clutch issues
    Could use some help. My 6000's clutch is getting harder to engage. It got so hard that I even had to pull up on the clutch after depressing it. After cleaning out a barn it got somewhat easier but...
  14. Q
  15. T
    Mahindra 6000 air bleed screw location
    Can anyone tell me where the air bleed screw is located on the fuel pump? Mahindra 6000 2wd...
  16. T
    Oil & Fuel Mahindra 6000 air bleed screw location
  17. T
    Loader Mahindra 6000 2wd&4wd measurements for a loader
    Could someone one give me the bolt hole measurements for a mahindra 6000 4wd? I have a 6000 2wd and trying to see if the loader attachment is the same for both. Thanks
  18. T
    Mahindra 6000 2wd Loader
    Does anyone know if there's anyway I can make a ML 264 loader work with my 2004 Mahindra 6000 2wd? It calls for a ML 260 but I've found a very good deal on the ML 264. Thanks
  19. T
    Mahindra 6000 Loader
  20. drdoolittle
    2009 Mahindra 6000 - stuck in first gear
    Yesterday out bush hogging, I stopped and shifted into first to weave in out and around a few trees. Now it won't come out of gear. I can shift between high and low, the PTO and clutch work...
[ad placeholder]
User Reviews (11)
Read what TractorByNet members think about the Mahindra 6000_3 Subcompact Tractor
5
73 %
4
18 %
3
9 %
2
0 %
1
0 %
3.00 star(s)
Anonymous Poster
6000_3 Mahindra
Mahindra 6000
Model Year: 2005
The tractor had issues when the right front spindle broke off. As I was scraping a driveway with the front loader, it broke off. The next issue was the clutch started slipping with just over 100 hours on it. The gasket in back of the motor came out causing fluid to get into the clutch, and I had to replace the clutch. The next issue is that the right rear brake sticks and has been doing this with less than 100 hours. They were supposed to fix this when I had the clutch put in, but they did not. Mahindra would not back any of this.
Pros: No service
Cons: Bad right spindle and bad gasket
4.00 star(s)
spark
6000_3 Mahindra
General Review
Model Year: 2004
A good tractor, value for the money, FEL could have a more lift capacity.
Pros: Does good job on what I have put it to so far.
Cons: A bit tight getting foot across from shift lever with winter boots on.
5.00 star(s)
ARL
6000_3 Mahindra
2006 Mahindra 6000
Model Year: 2006
Excellent tractor for the money. It does every thing I ask of it. Power steering filler would be designed better.
Pros: Heaviest tractor in its class. Best lifting power it its class.
Cons: Parts available on older from dealer.
5.00 star(s)
justusone
6000_3 Mahindra
Mahindra
Model Year: 0
I am well pleased with this tractor. I use it to mow, rake, and roll hay. I also sell firewood and run a small sawmill. This tractor is used to skid tree tops and logs in this process. I have a carry-all on the three point hitch that I use to move slabs and lumber stacks as well as place logs on the mill. Very strong hydraulics.
Pros: Very heavy and powerful for its size.
Cons: Hard to ground to the negative battery terminal. I've had to move the ground location a couple of times. Blows a lot of fuses.
5.00 star(s)
mohrt
6000_3 Mahindra
2003 Mahindra 6000 4WD
Model Year: 2003
Has really been a great tractor. I have a loader on it as well. It lifts almost anything I want and has treated me well. It has never failed me. The only issue I have had with it is the starter clicks occasionally. It might need a shim or something. I put an extra ground on it and that didn't fix the problem. It doesn't click much, just occasionally and has never not started. I had a friend borrow it who is used to John Deere and liked mine better. Very heavy, diesel engine is awesome, and the price is even better.
Pros: Price, design and mfg. quality, lifting capacity.
Cons: Starting clicking issue, not much else.
5.00 star(s)
timberfarmer
6000_3 Mahindra
Good Solid Tractor
Model Year: 2006
This has been a steady performer used in our forestry operations. This is a very tough tractor with 4wd. Use for maintaining roads, fire lanes, and planting. I like the weight of the unit---it handles heavy implements and the ride is comfortable. The only problem we have experienced is with the fuel system. Currently we have a difficulty removing air from the fuel system. Need to find the best way to do this.
Pros: Great tough tractor. Comfortable ride. Handles big implements.
Cons: Users manual is very poor and hard to understand.
5.00 star(s)
Anonymous Poster
6000_3 Mahindra
Unknown
Model Year: 2004
Since I just bought,got it I have nothing to report. I also have 1952 Ford 8N that has been in the family since 54. So I learned to drive on it.
Pros: Big enough. It has the quick attach bucket which I wanted.
Cons: The hour meter doesn't work. Have to figure that one out.
5.00 star(s)
jwp256
6000_3 Mahindra
Mahindra 6000 4WD
Model Year: 2004
Good tractor, plenty of power for pulling and loading. With 4WD, pulling a 10 ft harrow is easy. Only maintenance was repair to steering cylinder ($150.00) after 450 hours.
Pros: Good price for heavy built 60HP tractor.
Cons: Brakes are a little too close together (might be problem with my big feet).
5.00 star(s)
Cog
6000_3 Mahindra
Mahindra 6000 Review
Model Year: 2005
Nice heavy tractor. I have the 4x4 model and it does everything I need it to and more. I am very impressed with the Mahindra tractors. Alot of tractor for the money.
Pros: Heavy, powerful, FEL is great.
Cons: Starter issues on 400 hrs.
5.00 star(s)
sellercreek
6000_3 Mahindra
6000 is a workhorse
Model Year: 2006
My Mahindra 6000 4x4 has done everything I've asked it to do. Bushogging on steep ground, putting up around 500 4x5 bales of hay each year, grading and loader work, demolition of old barns and buildings, and feeding round bales each winter. Excellent machine and excellent value.
Pros: Powerful, durable, good value
Cons: Gearshift inconveniently located.
4.00 star(s)
imported_Charliechan
6000_3 Mahindra
Mahindra 6000 - 2WD
Model Year: 1995
Great all around tractor. Keeps going and going and going. Battery is hard to get to ! I did have to replace the front wheel bearings and wheel housing, somehow I cracked it. Cost over $1000 just for parts. Plenty of horsepower for shredding, post-holing, hauling large round bales and box blading. Only got it stuck once, but was able to dig-out with front end loader. Yes, I would buy it again if I had to do it all over again.
Pros: Iron Workhorse. Just keeps on going
Cons: Parts are expensive
Photo Uploads:
[ad placeholder]
Mahindra 6000_3 Owner Pages
View owner pages to see photos, customization and comments about member-owner Mahindra 6000_3s
Mahindra 6000_3 Community Rankings
#138 user rating of 1508 50-100 HP Tractors items
#80 Viewed of 1508 50-100 HP Tractors items
#23 discussed of 1508 50-100 HP Tractors items
#932 user rating of 19625 items overall
#618 Viewed of 19625 items overall
#215 discussed of 19625 items overall
