How To Plumb Well Water Lines for 2 Homes
   / How To Plumb Well Water Lines for 2 Homes #41
+1, great answer!
Consider using pex underground inside larger sleeved pvc pipe. If you ever have issues, sleeved lines are easily repaired with minimal/no digging.
   / How To Plumb Well Water Lines for 2 Homes #42
Per Gould's Spec Sheet:
It is allowable to run branches off the pipe between the pump and the transducer/pressure sensor as long as no flow restricting devices are between the pump and the transducer.
Yeah Goulds uses a transducer, which works for that but has other problems. And the pipe and fittings can be a "flow restricting device between the pump and transducer". Make sure to use pipe that is large enough not to cause any restriction in this area.
   / How To Plumb Well Water Lines for 2 Homes #43
I don't understand why you would have the controller and pressure switch at the house instead of at the well. You have to have power to the well regardless. Just put the controller and switch at the well.
   / How To Plumb Well Water Lines for 2 Homes #44
Because:
1. The controller/switch are best located at or near the tank
2. Controller/switch, tank, fuses, etc. should be easily accessible, not in a hole in the ground.
   / How To Plumb Well Water Lines for 2 Homes #45
Because:
I still don't get it. Must be a northern thang. All our wells have the tank, controller, and pressure switch at the well.
   / How To Plumb Well Water Lines for 2 Homes #47
As a fellow Floridian I can understand your confusion .... we do not have to worry very much about freezing. A simple shed or even a garbage can can keep our pump equipment from freezing on those few days when we MIGHT get cold enough for that to be a problem.
In other areas where they not only have freezing worries, they also have basements and/or garages where they put things like this to keep them out of the weather.
Additionally, unlike Florida, where the well casing is terminated above the ground level, they terminate the casing below ground level (below the freeze line) to protect it from the cold - thus a "pit" is needed to access the well head - and they run all the pipes that deep or deeper. Because that pit is a bit of a pain to work in, an enterprising man (about 1941) developed the "pitless adapter" so the the drop pipe (and pump if submersible) can be pulled without actually having to try to work in the pit.
By using this method, well and/or plumbing work can even be done on very cold, freezing days. They can even replace the tank, switch and/or controller in relative comfort instead of having to dig mounds of snow from the well area and getting all wet in below zero weather.
Don't get me wrong, I know there are some additional cold days up there in Seminole Country that we here in Gator Country don't have to deal with, but Leon County never has the type of cold they have in Colorado, Canada, New York and almost any place a bit north of Thomasville.
Can one connect PEX to a pitless adapter? I am looking to do this setup:
   / How To Plumb Well Water Lines for 2 Homes #49
Yes but be careful of size as you don't want any restrictions between there and the transducer.
I am going with 1.25" PEX line from the pitless. The drop pipe is 1.25" Schedule 120 rigid PVC.
I am going with SharkBite PEX.
Is it OK to run the PEX and the insulated pump wiring in the same conduit? (SCH 40 pipe - 2" conduit)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
John Deere S350 (A60462)
John Deere S350...
1454 (A57192)
1454 (A57192)
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
