how do I get my NPT connections to not leak
   / how do I get my NPT connections to not leak #11
I've found you have far less chance of leaks if you allow the sealer to set over night before putting them into action. Some sealers work regardless but many don't.
   / how do I get my NPT connections to not leak #12
Using permatex pipe dope is fine. There are two types. The types with chunks, and the smooth. The stuff with chunks is junk and doesn't dry. With the smooth stuff. Make sure the threads are clean and dry. Any oil or water, and it won't seal. I use break cleaner to clean the threads.
I've found that if I let the permatex dry up some, it seals better. I coat my threads, let them sit for a half hour or so to partially dry out. Then install. You want it mushy but not really sticky if that makes sense :)
   / how do I get my NPT connections to not leak #13
For hydraulic fittings that are steel or stainless steel, generally I get them as tight as I can muster. They normally won't deform up to that point. So snug the crap out of them. Regular plumbing fittings that are plastic or brass are a lot more fragile and those I am far more gentle with.
   / how do I get my NPT connections to not leak #14
Proper NPT hydraulic fittings are made of forged steel. Using normal length wrenches for the fitting there is no way you can over tighten. First thing happens is the corners of the wrench flats will round off if using open end or adjustable wrenches. If possible always use 6 point wrenches. Flare nut wrenches in the heavy pattern are great around hoses and tubing. Things that cause your leaks are: not tight enough, wrong lubricant/sealer used, damaged threads. SS or Forged steel on both male and female sides will not stretch unless you use a cheater bar. Over-tightening brass and malleable iron will stretch, cast iron will split, and internal threads in cast iron will strip out.
I very seldom have a leak in anything unless the threads are damaged or mating surfaces damaged or dirty; after many thousands of joints (not weed).
Ron
   / how do I get my NPT connections to not leak #15
If the threads are clean and dry I use Locktite 242 blue thread locker. If oily I use Teflon tape. I tried the liquid Teflon products many years ago but couldn't make them seal because they don't harden. They just pushed out at high pressure. Never tried them again. I rarely have anything leak.
   / how do I get my NPT connections to not leak #16
Do not remember the name but the hydraulic hose place here sells a teflon sealer similar to Rector seal but has a quicker drying solvent and have never had a problem with it leaking.
David
   / how do I get my NPT connections to not leak #17
You guys are working way to hard! Use a good quality teflon tape wrapped around the threads so that the tape gets tightened up as it goes in. I use 2.5 - 3 wraps. Tighten moderately tight and no leaks. If the flats on the fitting are starting to round off as you are wrenching you are plenty tight. I can't remember having a hydraulic leak on pipe fittings.
I know the code around here for natural gas is one time use only. They found there were too many leaks if pipe fittings were reused.
   / how do I get my NPT connections to not leak #18
That's because NG installs use malleable black iron fittings. They stretch like crazy when over tightened. When I was a service tech/installer in the industrial mechanical world we never re-used CI, brass, or malleable fittings for that reason. When someone is paying the bill you cannot afford call backs you can't get paid for. Fixing a bad install can take 3 times the labor.
Ron
   / how do I get my NPT connections to not leak #19
Agreed. I like the heavier yellow teflon (for fuels/gas).
   / how do I get my NPT connections to not leak #20
Loctite PST 545 or 547 if I remember correctly, pipe sealant that comes in a tube.
2003 Big Tex 10PI...
207282 (A52708)
207282 (A52708)
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
1605 (A57192)
1605 (A57192)
