Bet Your Towing Illegally!!!!! So Check Your Balls!!!!!!!
   / Bet Your Towing Illegally!!!!! So Check Your Balls!!!!!!! #31
This looks real safe! Ha
I'm surprised someone hasn't posted a freeway photo of one of those clamped on a tailgate, towing s skid steer. :)
Bruce
   / Bet Your Towing Illegally!!!!! So Check Your Balls!!!!!!! #32
Bruce
As close as I could find lol
   / Bet Your Towing Illegally!!!!! So Check Your Balls!!!!!!! #33
IMG_1454.JPGIMG_1456.JPGIMG_1457.JPGIMG_1459.JPGIMG_1460.JPGIMG_1461.JPGIMG_1455.JPGIMG_1458.JPG
   / Bet Your Towing Illegally!!!!! So Check Your Balls!!!!!!! #34
Lot's of great discussion guy's i didn't even know they made a clamp on hitch system for cars, tractor buckets yes, but cars???:eek: what were our forefathers thinking, however they did with what they had and i think this seems to be at a time when only one family car per family was the norm. Keep up the discussion i'm learning and so is some newbie member out there that has never towed a trailer before. Thanks again
***and then there's this learning curve..... but possibly could have been prevented by checking the weights on things...........
RV wipes out, totaled, only 2 minutes after couple buy it - RV Travel
   / Bet Your Towing Illegally!!!!! So Check Your Balls!!!!!!! #36
If you want to save weight, use aluminum balls.
   / Bet Your Towing Illegally!!!!! So Check Your Balls!!!!!!! #38
For the people that every ounce counts! They will never rust either!
   / Bet Your Towing Illegally!!!!! So Check Your Balls!!!!!!! #39
You can’t even upgrade to a Big Gulp for that, better stick with the small size.
   / Bet Your Towing Illegally!!!!! So Check Your Balls!!!!!!! #40
There was a day bumpers were built a little heavier. They were also used to jack up a car for tire changes. Hook a chain on one for a pull.
THREE POINT ATTACHMENT (A58214)
THREE POINT...
2015 KOMATSU WA270-7 WHEEL LOADER (A60429)
2015 KOMATSU...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2019 GALYEAN...
20.7kW Aptos 440W w/ IQ8PLUS Enphase Microinverter Solar System (A59228)
20.7kW Aptos 440W...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
