/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #961
Tack welded hood didn't hold up to the vibration it got.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #962
I have the roller all the way and ski up to top -1, Next time I hook it up I will try it and put to your setting if too high.
Thanks for the advice. How is your Flail holding up?
Ran all my trails and future pastures with it once, did well. It does seem to really ground the tractor and make it more stable.
Gonna give a second go this week.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #963
Ran the flail on the trails and the area I partially cleared of the dead ash trees. I did put the roller down one more hole.
Did a great job , but the supplied clips keep disappearing. The ones I have as spares don't fall out. Will need to buy more.
Put the Back Hoe on the Dolly I built:
Seems very sable.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #964
I picked up a 1993 murray 42" mower and tossed it down back until owner grabs it. can't find specific parts needed for the particular tecumseh engine in it.
massey beats murray.....
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #965
So, I have a guard over my fan/oil filter. Self made and it's worked well in the woods/brush so far.
But somehow branches are just attracted to the fan like bears to honey.
This time no damage, but pulling the stick out was scary after hearing the blades hit the end of it.
This was a long branch with a thin end, so just fit in....
Flail is working well though, went and dug out more rocks I found embedded in the ground.
Could be a new rock garden coming up with so many smaller 2-5lb rocks found!
Have to use them for something :cool:
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #966
Burned up the factory belts! Lol. Extremely tall grass, wasn’t being patient and didn’t have the nose up enough.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #967
Those belts do not look like they will take much abuse. You going with Kevlars?
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #968
I have a second set I ordered with the mower, those look better then the factory ones and I will make them my spares. I ordered the Napa ones from the other thread and installed them.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #969
Quick and dirty grading/clean up/natural swale today.
Parking pad build last week.
23 holes for arborvitae last week.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #970
Fire pit!
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #971
First paying job with the Betstco flail. This is the job I smoked the factory belts on, no issues today with good belts.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #972
Ooooh... is that a barn... or an airplane hangar?? :love:
Nice job -- I can see where your belts would have had quite a workout!
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #973
Neighbors pole barn, it was very nice.
The cheapness of the factory belts I think was the biggest factor.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #974
getting ready to spread 50 yds of gravel for a cement pad for pad level addition to mobile home. grass part of area drops 6inches grade over 15 feet.
first had to dig out old broken small in ground circular pool (3+ feet deep) filled with rocks (smallest 25lbs largest 200+) filled with poison ivy with 4-6 ft deep roots that were over inch thick.
could not get under rocks to lift due to tons of weed matting. had to curl bucket around rocks press against brush guard and backdrag out to where we could safely (away from poison ivy) hold shovels against the rocks so I could get under them.
this pic shows amount I had backdragged before any digging and shovel/removal. pile was 6ft wide 6ft thick and 4ft high at the top point.
same pile other side shows somewhat of the grade issues on grass part.
just some digging had just started.
deepest part of this hole is 30 inches. before I had chance to set brake it rolled back a foot, had to stop pushing as hitch was lifting tires off ground.
I had already filled some using reclaimed dirt.still got to do section on right side but thats slightly shallower.
just about ready for 45 yds gravel now. need to do little smoothing reclaim some fill for the hole but dumped bunch in already.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #975
I got tired of my GC's backhoe hose situation so I fixed it with my second revision of a mounting block for the rear hydraulic hoses. I bought a 12" "jumper hose" that I use when I remove the backhoe VS slapping 2 dragging ends together down the PTO driveline area. I needed to clean out around the culver so it made for the perfect test and everything was 100% as expected.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #977
That looks a lot cleaner than how they just dangle all over the place on every other tractor. I ziptie mine up high and out of the way.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #978
Was backhoe hydraulic plumbing factory or something you added?
The plumbing and backhoe was factory. I did a different project where I added rear remotes to run a T'n'T kit I'm making and in the process redid the factory plumbing so that I could move the connections to that bracket I made. I damaged the factory hoses the first year I had the tractor when the line got pinched in the 3pt and it bothered me ever since how poorly thrown in it looks and how dangerous it is given that I run a lot of PTO implements besides.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #979
grr... low range slow speed due to high (foot tall) grass full power. caught landscaping timber while turning corner. shoved rear of tractor sideways.
cracked one side of bracket and bent other side. got to take to fathers house to weld. hopefully he has enough in torch to heat the bent bracket before we twist back, mines almost empty.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #980
As predicted by other members here, I use the forks attachment on my loader way more than anything else. I’ve had two instances of not enough lifting capacity, though.
UNUSED FUTURE MINI EXCAVATOR GRAPPLE (A60432)
UNUSED FUTURE MINI...
UNUSED HYD THUMB (A60432)
UNUSED HYD THUMB...
CATERPILLAR 72" HANG-ON WHEEL LOADER FORKS (A60429)
CATERPILLAR 72"...
2013 International TerraStar Enclosed Service Truck with Liftgate (A59230)
2013 International...
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
SHOP BUILT TOOL TRAILER (A58214)
SHOP BUILT TOOL...
