Got wood?
/ Got wood? #62
Metal studs on exterior walls will transfer the outside temperatures into the house faster then anything else you can use. For extreme insulation on walls, they are saying that wood transfers too much heat or cold and they are using double walls with a thermal break to stop that transfer. While this does work, I think it's too extreme for what you gain on a wood stud wall. On a metal stud wall, it might be needed.
I had not thought of that but it explains why my interior walls only are steel stud. Exterior walls are wood stud. Excellent insight! :thumbsup:
/ Got wood? #63
No offense, but I disagree. Metal stud carpenters know how to work the product; I am much more comfortable, and successful, with metal vs wood. (wood is not my forte ) But then, framing is framing.
Are you disagreeing with the part about cutting more holes in the metal floor joists or the ease in working with steel? What is the correct tool for making these cuts? I'm curious what the pros use on these heavy, wide, floor joists. I would have used a sawzall with a good coarse metal blade to zip through them.
/ Got wood? #64
While many use screws to fasten metal studs, there exists special crimping pliers that create notches at the joints.
For cutting 3 bladed snips also works well and can be carried in a tool belt.
Either way you attach metal studding it kind of seems wobbly until the paneling is attached and it then is as steady as a traditional stud wall.
One advantage of metal studding is the fire deterrent feature as well as the pre punched holes for plumbing and electrical.
Might also affect insurance premiums.
It is simply awesome to see an experienced crew make metal stud divisions in commercial buildings.
Add to that a pro mudding and taping crew with bazookas and you'll never want to go back to wood studding and manual plastering.
However it is most effective for large spaces with long wall runs.
Had a friend that needed to build 70 ft of interior wall in his storage facility.
WOW, crappy 2 X 3 studs (read crooked with bark edges) @ $6.00 ea?
1/2 inch particle board @ $20.+?
City had a project that was estimated @ $500K but when they went to tender the bids were all in the 1.5 -2. mil range.
Project was abandoned!
/ Got wood? #65
We need to establish what we are working with here; Are we talking 25 gauge material (basically recycled beer cans and not worth 2cents) and should never be used.... , 20 gauge EQ"s (basically good for non structural interior walls to hang drywall) I would use tin snips or a good chop saw with a metal blade; fasteners- sharp point framing and drywall screws. 20 gauge structural where your walls may carry a load (kitchen cabinets, etc) then same tin snips or saw, fasteners- self tapping . 16 gauge is for heavy structural, second floor, outside walls with a veneer surface, floor joist, etc. Same chop saw or a portable band saw works well too. The best tool you will need is an impact driver and self tapping screws. The reason metal framing is so fast is everything needed can be carried in a tool belt, for the most part. Oh... don't forget magnetic levels.
/ Got wood?
I know wood is up, but I'm not sure what the price is for trusses are normal. I just paid $134 for a 24' truss with 10" overhang and a 1:12 pitch, 2x6 legs.
/ Got wood? #67
I thought we were talking about fatjay's floor joists. They are 12ga, and too wide for a portable band saw but maybe a large chop saw would work? That's why I was asking, since it seemed like a sawzall would have been my tool of choice. I've never built with steel like he's doing and I'm learning from his garage thread.
/ Got wood? #68
3 months ago I paid $90 for 24' 4/12 with 24" overhang, and $94 for an end truss.
Today they are $100 and $144 respectively.
Those are 2x4 construction.
/ Got wood? #69
can metal studs be cut on any angle besides a straight cut? I see metal studs used in a lot of modern design buildings with no pitched roofs, they're all flat roofs where angles don't to be cut.
/ Got wood? #70
I haven't seen that thread. I'll check it out. Thanks
/ Got wood? #71
Yes. Metal is incredibly workable; just need to screw it off...
/ Got wood? #72
Its all just a scam too, we have 3 lumber mills by us. Huge piles of logs outside. Mill running 3 shifts. Huge stacks of wrapped wood outside. There shipping less to raise prices. I need to go snap some pics.
We have mills with large inventories and the woods are full of freshly burnt trees right for the harvest. A good friend faller of mine has not stopped working for several years now. I think the lumber barons are bending over the consumer for no good reason other than because they can. Me and a friend have a mill and timber so our lumber costs are measured in beer, hot peanuts and gas to run the mill. We have been at it for 40 years and only have to buy the products for construction that the mill can't produce. mill1.jpgmill2.jpg
/ Got wood? #73
Awesome mill. What make is it? How old is it?
hugs, Brandi
/ Got wood? #74
hugs, Brandi
Partner bought it in pieces from a guy who could not complete the assembly of it. It is from the 1920's and no brand as it was built from scratch. Good old Yankee ingenuity and a lot of sweat to get it running. We are replacing the building over it with freshly milled douglas fir beams and rafters and pine sheeting next spring. We have a 52" blade on it that will cut a 21"x 21" square cant if the logs are large enough. I have some 1"x20" board and batt siding on many of my structures.
/ Got wood? #75
It's not a conspiracy, there is a building boom, and public policy has run too many mills out of business. You still can't get a log out of the national forests, and timber counties in Oregon had to sue the BLM to get them to increase legally mandated logging. Plus, a lot of the mills have been shut down from the fires, and some big mills have been destroyed. We have been running about 1.2 million to 1.4 million housing starts a month. That's a lot of wood. The forests that burned are still on fire, and won't be salvaged until the winter rains put the fires out. Then there will be plenty of logs for two years, until they rot. After that, more mills will close.
There are still huge lumber trains leaving my county twice a week, of milled lumber and engineered wood products like glu-lams and TJIs. Some local lumber shipments go by truck, but the vast majority go by rail. Trucks don't have adequate capacity, either for size or weight.
/ Got wood? #76
Thank you for pointing that out, I thought that I was alone here. Besides, what we've posted is boring stuff. Everybody prefers a good conspiracy theory.
We've seen jobs lost, while Canadian lumber goes flying down the interstate. For the first time in years the mill owners here are seeing some good times. I only hope they realize these prices can't stay and are investing in infrastructure.
/ Got wood? #77
There is a huge demand for lumber products as mentioned which partially justifies the huge price increases. We have mills working their maximum production possible and still log decks from 2 years ago fires sit and rot in the hills. Anyone that can pass a drug screening can work here for a decent wage but ironically the work is too hard for some slackers. The forest policies have led to the closing of many mills in this area and the forests are full of dead and dying trees from insect infestation and poor management. I paid 35 dollars a sheet for 1/2" CD plywood the other day when last time I bought it 6 months ago it was 15! I think the demand and price will fall at these prices!
/ Got wood? #78
The viking,
Where is here?
hugs, Brandi
/ Got wood? #80
Lumber peaked in August. It has fallen around 45% in commodity pricing since then.
Prices will be falling here shortly.
