PTO generator for bx1830
   / PTO generator for bx1830 #1
cdrew
Windham, maine
So, with the latest ice storm, I've started looking at generators. I posted to the attachments forum with no real answers. I figured maybe the bota forum would yield more.
I have looked at these on the web.
NorthStar
Winco
Baumalight TX
The Baumalight is the only one I can find with 11 pto hp required. The others require 14. The bx is 13.7.
If I'm only pulling 2-3k kw will my tractor be fine with the "cheaper" gens that require 14 pto hp, or am I way off the mark in thinking that?
Or, should I just get a gas stand alone unit. I like the idea of not having yet another motor to fix/repair/keep going. That's why I got the snow blower attachment for my bx, which I LOVE.
Thoughts, concerns?
   / PTO generator for bx1830 #2
You found some nice generators. I've been thinking of getting one of the pto driven units myself. I just need to learn more on how much power I need to run the house etc.
I have a gas powered 5500 watt generator now that I've never had to use but I do make sure it starts every year. ;)
I hope others will chime in with some thoughts.
   / PTO generator for bx1830 #3
You generally need about 2x the HP as kW so if you have 11HP at the PTO then you can generate about 5.5kW. If one 7kW gen is listed as 11 HP needed and another is listed as 14 HP needed then someone is fudging numbers.
In any event, you can run a larger generator than your PTO HP allows...just don't load the generator to full capacity. If you hear your tractor engine bogging down and the generator frequency drops way below 60 HZ then remove some of the electrical load.
   / PTO generator for bx1830 #4
A pto Gen ties up your tractor to where you can't use it for other task unless you have other tractors as I do.
It also creates the situation where you have more hours on the engine than on the tractor.
L . B .
   / PTO generator for bx1830 #6
I'm guessing these topics will be popular for a few weeks at least here in NH - we got our power back yesterday (thank you PSNH guys!) after 6 cold and dark nights. Was thinking myself that my BX in the garage would make a darn fine genset powerplant. But think I'll wait until the profiteering dies down come spring before pulling the trigger.
   / PTO generator for bx1830 #7
Cdrew,
I have the Baumalight TX12000 for my BX23. I got it earlier this year, but haven't actually had to use it yet. (Other than testing the circuits after my generator panel got installed.) It's a pretty nice unit. I think I saw someone here on TBN say, that you should buy a little more generator than your tractor can handle, because if you're like most other people, sooner or later you'll get a bigger tractor.
   / PTO generator for bx1830 #8
Just a suggestion;
This is what I do, I have a 2000 watt Honda inverted generator that I normally use for my Rv when we dry camp. You can back feed it to what ever outlets you might need to power. Mine is back fed on my deck outlet and runs my refrigerator, tv and lights and furnace.I can get by for a few days with that setup. the cost of the Honda is about $1000.00 and it is very fuel efficent. I do have a much larger Honda if I want or need to run the whole house. My neighbor,(Dairy farmer) has a PTO generator that he runs from an big IH 1496, it powers his barn and house. Of course he does not worry about how many hours he has on tractor as he has manny.
Rick
   / PTO generator for bx1830 #9
Unless I've misread something here, he said his PTO hp was 13.7. That means it will run any of the 7kW generators he mentioned. OK, so he may not get the full 7kW but he will be so close I don't think it'll be noticeable. That 2hp per kW thing is just a rule-of-thumb, not a hard and fast law of physics. I'm not familiar with the Baumalight model but I think I'd go for one of the cheaper 14 hp products. As I recall, some members here have had good things to say about the Northstar pto generator. Do a search.
   / PTO generator for bx1830 #10
There is some amount of science to the 2Hp per KW rule. The number falling outside that range is probably using a peak, not continous measurement. We sell lots of Tiger Power 10KW's. The 10kw is continues, they peak to about 12.
   / PTO generator for bx1830 #11
I bought the 13kw version a few years ago, running it on my L3830. Thankfully, I've only needed it once, but it was great. I ran it for about 30 hours and it performed flawlessly. The only quibble was that the power output wasn't clean enough for our stereo amplifier, it went into "protection" mode, so we had to use the television's built-in speakers. Oh, the humanity! ;)
Cliff
   / PTO generator for bx1830 #12
your probably finding the difference between capacitor regulation, and AVR. Somthing to read up on if you have alot of electronics.
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
2020 Ford F-250 Ext. Cab Service Truck (A59230)
2020 Ford F-250...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
