Reclaiming a long-lost field
/ Reclaiming a long-lost field #41
Looking at your photos, I suspect that your hidden rocks are a lot like mine, the more you dig to remove them, the more you find. I think that if I removed all the rocks from some of my hills that I would end up with a valley.
Good job on all so far, but be prepared to be forever picking up rocks every spring after Mother Nature hatches a new bountiful crop during the winter.
This rock truck will be used to haul the stumps to the stump dump. The ground across the field is pretty rough for a road truck and it won't get much better until the stumps and rocks are out of the way to allow some grading.
I finally got some topping on the lane to the field. It was 6" smooth/round rock like at the right in the pic. Driving on it will work the fines down into the rocks and lock them in place. It was neater than that until they skidded logs on it, which was a bad idea for loose rock. RDrancher would be appalled, I know :laughing:, but now we can use it without twisting an ankle or shaking the tractor to pieces.
I'm in for it with the rocks, for sure. Some areas aren't too bad and some are really bad. I'll have to see how it grades out.
I think there will be rocks that sort of crown at the surface but not high enough to have to go around them mowing. Sometimes those stay put and sometimes they keep creeping up with the frost heaves. There are some that are just too big to move but some grading can taper the soil around them. There are several that will be obstacles forever.
The stump and rock wall removal and trucking is done. Plenty of picking up yet to do this fall.
The stump dump got pretty well filled. Enough dirt was carried on on the roots and squished to the surface by the weight of the rock truck and bulldozer that the top of the dump will be able to be bush hogged for the most part. From past cases of burying brush, I think it will be years before much changes there. It will be interesting to watch though.
This is about the same view from the side of the stump dump as post #39. The level top area is much larger now than at the start.
View from the lower end, also as in post #39. We didn't pretty this up because I have trees and stumps to dispose of somewhere every now and then. They can be added to the end as needed.
Some pics of removing the rock wall. It ran across the center of the field. Most of it was just a mess except for about 50-60 feet that had never been skidded over. I decided to just get rid of all of it. They are a pain to keep the trees from growing next to them where the bush hog can't cut, besides living with a barrier across the middle of the opening.
Having the rock truck made a huge difference. The contractor said without it, we wouldn't have been able to do it the way we did. I could easily see that. It allowed working from all over the field whereas a road truck would get torn up and stuck doing that. He rented it; it's for sale in Madison, ME if anyone needs one. :D
Loaded rock truck. Interesting factoid: the wagon portion of these trucks are made to tip over. At the articulation joint behind the tractor portion, there is a swivel. We didn't test it thank goodness but it had been on its side sometime or other. The load rides high. There is a safety decal inside saying if the wagon tips, hang on to the steering wheel--do not jump out.
Loading rocks from the wall.
Some of the rocks were trucked here to provide the base for a truck turn-around at the entrance to the field. It was a mostly useless small, low corner area behind a ledge outcropping, so I made something useful out of it. :)
The next step is about a month of rock picking I would guess. Depends on the weather and my age. :laughing: The contractor loaned me a 10' piece of heavy I-beam with loops welded on each end to hook up a chain or cable. When I get tired of picking, I can drag that around from the tractor's draw bar to do some smoothing.
I want to get the field in the best shape possible before planting anything, so I think it's important to be patient with this next step even if it means delaying planting until spring. It would probably be good for the seed bed if the soil weathered a bit over winter and got smoothed again in spring anyways.
/ Reclaiming a long-lost field #46
Impressive progress. Looks like you are using the right equipment for the job.
/ Reclaiming a long-lost field #47
My goal at this point is grass hay, which I think goes with developing healthy pasture. The hay around here is mixed grass hay for the most part.
Boy does the winter wind howl across that opening some days. .
Good Morning Dave,
Looks like your making some real progress ! Very nice !
I can relate on the wind issue !:)
Thanks guys. So far the progress has been mostly watching big equipment and writing checks. Next comes the sweat equity part. :eek: I put nine hard hours into it yesterday and even though I was working on some of the ugly parts, I can see it's going to take awhile.
/ Reclaiming a long-lost field #49
Morning Dave... just seeing this thread ... looks like quite a project! Have no idea of the cost but have you considered getting in a tub grinder in for those stumps?
I thought about it but didn't look for any tub grinders in the area. I don't know how well tub grinders deal with rocks and it would have been a time consuming process to feed it rock-free stumps. It would have made a nice pile of compost after 5-10 years.
It's too late now :), they are banked in that dip and I can drive the tractor over all but the low end of the bank. Giving up the dip area was no loss, it would have been hard to make use of. The dirt is not deep enough to have leveled it out some. More digging there generally just gets you more rocks, or ledge, a bit more than I suspected or was hoping for.
Overall, it's never going to be half the field quality that your oats are growing in. There are few decent acres here and there, but some is only going to be suitable for rough pasture I think.
/ Reclaiming a long-lost field #51
Hi Dave,
I enjoyed reading your journey from woods mess to field. Open pasture is great! Wouldn't we all like a rock truck?
If you are still looking for rock pickers, my grandfather is building a stonewall on his property on the coast and would love some!
Welcome, another Mainer on TBN! Getting to be quite a few from around the state.
Well, send your grandfather over. :) The nicer rocks for walls are deep-sixed now. About 2/3 of what I am picking up are the round types that are harder to stack. I wouldn't guess they would be worth hauling that far. The contractor did try a few contacts to see if the decent sections of rock wall could be sold by the truck load for landscaping/hardscaping, but nothing came of it. People do look for the weathered rocks with lichens and moss on them.
I tried out dragging the I-beam today. It is 10' long, 12" high, 8" wide, ~1/2 web, so it should weigh 40 lbs/foot, or about 400 pounds total. It works amazingly well. One pass over rough ground does quite a bit of smoothing. It tends to pop the rocks, chunks and bits of stumps/roots to the surface, which is a good thing for ease of picking. I'm thinking if I clean up what is on the surface after one pass, then make two-three more passes depending on the condition of an area, it should be pretty good.
I looked at a project here on TBN that used a land plane, but I think this may be too rough for those. I don't think land planes are made to deal with large loose rocks, ledge, root chunks and such, they do look good for smoothing and shaping clean dirt. After seeing the results of one pass, I can't imagine a land plane would do any better than the I-beam at this stage. It pulls harder than I thought it would. I was in 5th or 6th gear out of 12 (mid-range 1st or 2nd if you know TC40 gears) running at about 2100 rpms. That seemed to be a good ground speed for the beam to scrape and fill.
The only problem I had is I hooked two small stumps that were missed, and I bet there are a few more in there. That straightened out the connectors I was trying out on the 3/8" chain. I have some 3/8" repair links that I will weld shut for the next try. I need a closed loop at each end of the two chains. Normal hooks would bounce loose since the chain tension isn't constant.
I couldn't find the right combination of clevis sizes that would work together. Any clevis pin that would fit through a 3/8" chain, the clevis is too small to fit around the drawbar clevis I'm using, and likely too weak. The chain fittings rack at TSC was half empty, so maybe they sell what I really need but don't have it well stocked. I'm alternating backhoe and loader work with the I-beam dragging and need to be able to connect an disconnect the chains easily. Fortunately, the chains pass below the backhoe frame.
/ Reclaiming a long-lost field #54
Good Morning Dave,
Looking forward to some pics of your I beam in action !
Sounds like its doing just what you want from it. Are you going to wait till next year to take in some soil samples for analysis ?
/ Reclaiming a long-lost field #55
Good Morning Dave,
+1 :)
/ Reclaiming a long-lost field #56
Enjoying this thread, and the photos ...
I hate to see old stone walls, in any condition, go, but I guess we have to do what we have to do. Call me old fashioned .. or better yet, traditional.
/ Reclaiming a long-lost field #57
I've seem many chains made with a center loop for towing stuff, just by running a bolt/2 washers/nut through two links, maybe 8 inches apart.
Often end loops were made the same way, around part of the implement.
Bruce
Bruce
Thought about that. The largest dia. bolt that normally fits would be 3/8".
Part of the issue is the when the beam hangs up on something, the chain gets a pretty good jolt. It's not like using a hook and applying pressure slowly (usually) when lifting something or even like skidding a tree with the butt off the ground. On the other hand, I was thinking that there needs to be a weak link in there somewhere to avoid serious damage elsewhere. I wouldn't want to look back and see my draw bar laying in the dirt. :laughing:
Maybe I should use a punch to open up two links to accept a 7/16" bolt? What hardness grade bolt would you use?
Good Morning Dave,
I should be dragging again tomorrow. I will get some pics of the I-beam set-up and use. Spent today sweating while digging and picking up rocks. Whew, that sun was intense today!
The speed at which I'm making progress cleaning up makes me think I won't be planting this year. I could see clean-up lasting until it's too wet to do anymore this fall. I should get some samples fairly soon to see if lime is needed. I could get that down this fall and that should give it time to work. I need to ask about bulk lime availability.
Some pics of the I-beam.
I decided to weld the 3/8" repair links together after making 12-link loops. That held up for five hours of dragging today with no problems. I ran slower today in 5th gear of 12 (mid-range 1st gear) @ 1800 rpm and stayed in two-wheel drive to allow for tire slippage if I hooked something solid. Just trying to reduce the shock on the chains by going a bit slower and less power applied.
This gives an overall idea.
Shaving lumps off sod.
In deeper, loose dirt it can be carrying a decent load of dirt, rocks and root chunks. Sometimes a root chunk will get caught underneath the beam but eventually it gets dumped out. It often leaves a small pile of roots and rocks where it decides to flip over them. Once in a while the beam will flip over 180 degrees but eventually it flips back to right-side-up.
Just by luck and zero foresight on my part, the backhoe bucket can reach the beam and flip it if desired. I just let the beam do what it wants, the results are not going to change much.
2018 Forest River Flagstaff Pop Up Trailer (A59231)
2018 Forest River...
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
2020 CAT 308 (A53317)
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
Morgan 26ft Box Truck Body (A59228)
Morgan 26ft Box...
Adams 350T 10T Tender (A61306)
Adams 350T 10T...
