Welcome to my Nightmare!!!!
   / Welcome to my Nightmare!!!!
Highbeam,
I'm not sure which will be a happier day. The day I start it, or the day I sell it!!!!!
Greg,
I asked the mechanics at Case about the Headbolts and they say they re-use them.
Plowrup,
I picked upt he connecting rods today with the new bushings in place and hone out. The difference is HUGE from the fit of the old ones to the new ones.
I think I have a theory as to what happened with the engine.
The bushings were worn to the point that I hade play in the wrist pins by hand. I could wiggle the pins around in the bushings. The new bushigns are so tight that you have to get the wrist pins perfect for them to slide in.
Would slop in the bushing allow the piston to wobble around in the cylinder? I think so. Would this cause massive tapper and excessive wear? Again, I think so.
All cylinders had too much taper, but five and six were really bad. One and Two had new pistons in it, but the same slop in the bushings.
If the taper gets to a certain point, will the rings break?
This is what I think happened to my engine.
The picture is what the new bushings look like.
Eddie
Highbeam,
Greg,
Plowrup,
Eddie
I put a clean towel down and assembled the piston on my workbench. The hardest part was the snap rings on the sides of the pistons.
These pistons were made in Brazil and are identical to the ones that came out of cylinders one and two.
Eddie
Eddie
Here are the pistons and sleeves lined up in order. You can see the old sleeves in the background.
This is the majority of the kit. Gaskets and a few small parts were also included in it.
Eddie
Eddie
Pistons are in the sleeves, and torqued down to 88 pounds.
This was a big step forward!!!
Eddie
Eddie
Here is a picture of the cylinder head.
I had to re-attach the lifting brackets before I can lift it, but Steph came home about this time. Saved!!! /forums/images/graemlins/grin.gif
Eddie
Eddie
2019 RBR Venturi 380 (A55301)
2019 RBR Venturi...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2000 JOHN DEERE 444H WHEEL LOADER (A52705)
2000 JOHN DEERE...
