What Bends/Breaks First :) Stump pushing or pulling...
/ What Bends/Breaks First :) Stump pushing or pulling... #21
If ya pull with a chain from the draw bar ( good method ) be sure to use strong chain and be aware if the chain breaks or slips off the stump you can get killed when chain recoils and takes off the back of your head .
/ What Bends/Breaks First :) Stump pushing or pulling... #22
TMR, morning...I read thru the posts and did not see anyone mention what I am about to write.. I don't think I am duplicating anothers post.....
When pulling from the rear of any tractor, BE SURE to pull from below the axle / rearend... pulling from a point higher can and probably will flip the tractor over backwards. It can happen in an instant with deadly results...
Be safe, enjoy all those stumps...
@ sailorman and @ daveOmak...thanks for the good advice. Always somewhat dangerous around machinery...particularly so around tractors/trees and chainsaws. Wonder if anyone makes a ROPS "recoil" protector?
Also, pull pivot point needs to be remembered...TMR
/ What Bends/Breaks First :) Stump pushing or pulling... #24
TMR If you can get an excavator I believe it works the best. You can dig stumps and pick them up and drop them to get extra dirt out of the roots. I recently got a Komatsu 135, and spent about 4 hours and pulled around 40 stumps ranging from 3" to 30" I actually could have gotten away with a smaller machine, just would have needed to dig a little more. Used the tractor to move the stumps once they were out as After 1 day you pay for hours on the machine. Just a thought.
/ What Bends/Breaks First :) Stump pushing or pulling... #25
A few of us recommended using the draw bar, which is mounted below the rear axle...I've never seen one mounted anywhere else.
Also, as nice as the pictures soulasphil posted...note that he wasn't using his ROPS (folded down is just about the same as not having a ROPS). Also, no rear ballast.
No reflection on soulasphil, but that's an accident waiting to happen.
Please do use that safety gear
/ What Bends/Breaks First :) Stump pushing or pulling... #26
A single point "ripper" with a strong blade would seem a good tool. Is there such a thing made commercially for those of us not "skilled" enough to make our own? I assume you would have on 3 pt and set in the ground to rip on the edge roots?
Thanks...TMR
Your FEL is designed for scooping & moving material, not bulldozing. As attachments go, it is very expensive. Don't damage it doing something that can be done better with a cheaper, 3pt implement.
I think you are on a good track with the subsoiler idea. They can be had at TSC for a reasonable amount. Just be sure to get a well built one. Do a search on subsoiler and you will find that certain models have a history of bad welds. I use one and rip around the stump to bring up as many supporting roots as I can - this will make your chain/drawbar work much more rewarding.
You asked about recoil protection - I use ropes a lot and they have a bad reputation for stretching & letting go - here's what I use:
-Jim
-Jim
Thanks Jim...I like your ROPS add-on. Seems like that should help if either a rope or chain broke. I also think the ripper would be of great help...I think it might even rip the stumps right out.
Also, I think you could "work" the ripper quite hard and not damage any equipment?
Thanks for the ideas and pictures...TMR
/ What Bends/Breaks First :) Stump pushing or pulling... #28
Use a chainsaw and cut a small notch about 1-2" into the stump. When you wrap the chain around it, put the chain in the notch, and pull from the opposite side. The notch *should* keep the chain from popping off the stump as it moves upward.
/ What Bends/Breaks First :) Stump pushing or pulling... #29
bcp said:
Or cut a basin in the stump top with your chain saw and plant flowers in it.
Bruce claimed he was joking, but I've actually done that. The heartwood under the potting soil decays fast. A 30-inch oak stump rotted out in ten years, to the point where I took it out with a mattock. It looked nice and picturesque the whole time. Doing that with a hundred pine stumps might look kinda weird, though.
/ What Bends/Breaks First :) Stump pushing or pulling... #30
Why not rent/hire a stumpgrinder, no holes to fill in, no burning required etc,gets your ground to were you want it quicker without busting your gear or yourself:thumbsup:
/ What Bends/Breaks First :) Stump pushing or pulling... #31
Here's 16 inch Ash stump that I dug out today. It has been dead a couple years - Emerald Ash borer. I had left a six foot stump on and I tried pulling it before digging and it would not budge. It didn't take long to break the roots with the backhoe and get it loose. I used the thumb on the backhoe to pick it up out of the hole after it was loose and set it on the ground so I could pick it up with the forks. It took a lot longer cleaning up the roots and leveling the hole afterwards.
With as may stumps as you have, if they are not rotted, I would rent an excavator for a day (get one with a thumb) to dig them and then haul them away with your tractor.
/ What Bends/Breaks First :) Stump pushing or pulling... #32
Thanks for the kind words regarding the screen - I think it would stop a stout rope, but I wouldn't count on it to stop a 5/16" chain - though it is better than nothing.
As long as you work slowly with the ripper I don't think there's a lot that can get damaged. I still need to make a shear bolt arrangement on mine - more for when I'm using it in the field & at a good clip than when I'm grubbing roots in granny gear. Being right at the hitch pins, it can exert some whopping force when pulling up with it - way more than my FEL can deliver - and I don't get tippy or go looking for ballast. One down side is if I use it to pull the stump out I usually cut the stump close to flush with the ground - otherwise it's always in the way of the subsoiler, one of my rear tires, our the soft orange underbelly of my 'bota.
This works great for a few stumps that you can get all around. If you have a lot of stumps or they are hard to access from all sides, I'd go with the advice to rent an excavator or use a backhoe.
Well...I think the "ripper" may work quite well. I went out to do some tree work today and took a heavy maul with me. The stumps are well on the way to "rot" I could make a pretty good mess with the axe portion of the maul. I would think I could rip near the edge and effectively pull the stump and roots out...at least what remains intact. I tried this on 2-3 and they at least 1/2 rotted.
I want to extend a trail along a ridge that has quite a few stumps...would probably work pretty well and should not be too many stumps to rip out.
BTW...I would guess a moderately heavy frame tractor is better for this type of brute force work that a small frame...and more weight is an advantage? Supports the bigger/better "urge". :thumbsup:
Thanks...TMR
/ What Bends/Breaks First :) Stump pushing or pulling... #34
I wouldnt worry too much about a chain recoiling especially if it is hooked at the drawbar. It will recoil lower than the angle it is in when it slips which will be at most up betweeen your rear tires. Chain doesnt recoil like rope or cable as the links tend to absorb the recoil. I have broken 3/8" chain and the recoil never reached the tractor. You wont get more recoil than that from a slip. I would never use rope for pulling stumps due to the stretch and recoil factor. I only have longleaf pine on my place and they dont have much root structure so I expect that your jackpine would be similar. They should come out easy enough with the FEL. I would try centering the bucket on the stump and ease into it with the tractor to check it. It may just hull right out of the ground. I push over a lot of green pine up to 8" in diameter and they usually come out easy. I dont think you will damage your FEL if you dont ram it into the tree and if you keep it centered. Trying to lift with one corner will spring the frame, been there done that before I knew better.
/ What Bends/Breaks First :) Stump pushing or pulling... #35
Drape a heavy rug, blanket, or winter coat over the middle of the chain. That will damp the recoil if the chain slips or breaks.
Although as Gary said, it's more of a prob with rope or cable.
/ What Bends/Breaks First :) Stump pushing or pulling... #36
I suggest you pull them with a chain on the tractor's draw bar. That's about the strongest part of the tractor.
You can loosen the stump with the loader...just don't over do it. But when you pull it out, use the draw bar!
I'll probably catch heck, but I disagree. A stump is a classic "Immovable" object and when a tractor tugs hard enough on one, it will flip. Many people have been crushed from having a tractor flip over on them. And I'm about as far from being a "Safety first" guy as they come.
Use a middle buster to cut the roots, then dig them out with the FEL.
You can also force them to rot quicker. Drill several holes into the stump from the top, sprinkle a cup of high N fertilizer on them and cover completely with mulch. That will accelerate the decay process 10x, costs little, takes little effort and won't harm your equipment or you.
/ What Bends/Breaks First :) Stump pushing or pulling... #37
I use chain at the drawbar, then hook it to cable (if needed- I spent today pulling dead locusts 200 feet down the hillside, with a snatchblock on a tree at the bottom.) That way any cable breakage happens at a (short) distance from the operator.
Didn't the TV Mythbusters guys disprove the "cut a man in two with a cable" myth, using a pig's carcass?
As for flipping over backwards, that was more of a problem with the old high wheel farm tractors- especially narrow front end ones. AS one of the gurus said a while back, the drawbar is below the axle, making it close to impossible to flip the machine.
/ What Bends/Breaks First :) Stump pushing or pulling... #38
There's a video we had to watch for flight deck safety when I was in the Navy. One of the sections showed an arresting gear cable parting and took a sailor in two...just above the legs.
So, yes, a cable can slice a body in two.
That, of course, was a pretty extreme example. But any cable that parts under tension can do damage or injury.
/ What Bends/Breaks First :) Stump pushing or pulling... #39
If it was me, and because I have the choice between a full size backhoe and a dozer I would rent a small dozer. A stump that size is real easy for my Case 450 to push out of the ground.
Why do I say rent a dozer? Because your life is not complete until you've had a chance to play on one. Tractors are great but the dozer puts a smile on your face that even the worst wife in the world can't remove for days. Everyone who has come up and played, I mean worked, with the dozer has left with a sh^t eating grin from ear to ear.
If you do try it with a tractor I would use some caution. I once watched a neighbor turn his 2" receiver into a pretzel because he though his 3/4 ton could rip shrubs out of the ground. I don't know much about the Deere's but the GL3x40 line is a nice solid tractor.
/ What Bends/Breaks First :) Stump pushing or pulling... #40
I'd try the tractor, use common sense. If it doesnt work it out relatively easily, get something bigger and made for the task.
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2005 Chevrolet C4500 Altec Bucket Truck (A56858)
2005 Chevrolet...
2016 FREIGHTLINER CASCADIA SLEEPER (A59905)
2016 FREIGHTLINER...
2013 Ford Escape SUV (A59231)
2013 Ford Escape...
2019 Peterbilt 579 SLEEPER (A59905)
2019 Peterbilt 579...
