sd455dan
Super Member
- Joined
- Oct 23, 2012
- Messages
- 6,344
- Location
- North Idaho
- Tractor
- Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
looking at a t234 tym tractor, its 25 hp and the fel is rated at 1380lbs lift at the pin,with over 2000lbs breakout force,, compareing it to many john deere models, it beats their loader rateings ,on the green tractors on models with over 35 hp,, im baffled . Im looking at used jd models mostly, because they cost alot more than the tym. Im looking for a tractor that is light enough not to crush sprinkler lines and rut residential lawns (badly), but still be able to pull a 5' box blade,and dig out my ditch line. I have a 1963 ford 4000 now,its to big and heavy for my custemers yards.
Have you looked at the specs for the New Branson 2515's in comparison
don't know if dealers have them in stock anywhere yet but in the under 25 hp group the new 2515 h and R are impressive spec wise
(24.8hp engine, PTO 21HP)
3 range Hydromax hydostat engine speed linked to hydro pedal
diff lock
cruise control
3 point lift 24 in. behind pins 2425lb
2200lb at pin to 104 inches FEL lift with quick attach 3660lb breakout force
Suspension seat
Maybe to heavy since shipping weight is almost 3k lb.?
