Massey Ferguson 50_4 3.30 star(s) (3)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Massey Ferguson 50_4.
25-50 HP Tractors
About the Massey Ferguson 50_4
Massey Ferguson 50_4 Discussions (124)
Here are the most recent 50_4 topics from our community.
  1. D
    What bolts for the front hydraulic pump adapter plate to crankshaft on MF-50?
    Hello, I'm adding a MF-101 Loader to my MF-50. I ordered the pulley below and my crank pulley has what appears to be three holes with 3/8" threads. What bolts are supposed to be used? The...
  2. J
    Mf50 serial #
    I have an mf50 that has been passed down to me that was purchased new by my grandfather. Serial tag reads sgw 537382. All of the searches I have done to identify year etc do not show this s/n...
  3. N
    MF 50 Owners Manual
    Cleaning out the home office area and came across this publication. I had bought it used when I acquired a MF 50 back in the 90s. I sold the tractor probably 20 years ago and forgot about the...
  4. T
    Massey Ferguson 50 clutch kit Questiuons
    I have a Massey Ferguson 50 split to replace clutch and pressure plate. Looking for best options for a new clutch and pressure plate kit. The pressure plate has broken bolts and spring pieces that...
  5. J
    MF 50
    Hi All, I am searching for a manual for what i think is a mf50a or r? The serial number is MF50 836990A, It has 4 clamping cylinders that hold the backhoe in place while digging, one of which is...
  6. S
    Massey ferguson 50 paint
    What is the orginal colors of a Massey Ferguson 50
  7. C
    1964 mf 50
    was looking at a 1964 mf 50 gas with power steering good tires not restored runs great is 2000.00 a good price
  8. K
    MF50 rear wheel locks up
    I have a 1962 MF50 4cyl gas tractor. Sometimes when I'm snow blowing in reverse the left rear wheel locks up. Forward is OK. Go back and forth and the wheel frees itself. I've disconnected the...
  9. malightcommander
    MF50 industrial grinding gear problem
    Hello all, I'm new here, so I think a small introduction would be good. A couple of months ago I have bought a 1971 Massey Ferguson MF50 industrial (backhoe) tractor, here in Sweden. The label...
  10. Johnret
    Massey 50 PTO
    I Have a MF50 split to install a new clutch (dual). The reason for the split is the PTO fiction plate was completely burn out and shredded. With the tractor split should I be able to turn the PTO...
  11. W
    Massey-Harris-Ferguson MF50 Worth Starting?
    Hi all, I bought this MF50 Z134 a couple years back because it had a loader and it was (I thought) a good price but non running condition. The guy said the starter went bad and while replacing it...
  12. P
    MF50 Hydraulic oil loss
    I have lost most of the hydraulic oil out of what appears to me to be a weep hole in the bottom of the transmission gear box. Any help solving this would greatly appreciated. I'm brand new to the...
  13. B
    Mf50 massey 41 temro circulating heater
    My block heater packed it in at minus 33 so I bought temro circ heater was going to cut the hose supplying my cab heater which is coming from low point on motor and splice in and out of circ...
  14. G
    MF 50 Power Steering
    I have a MF 50 that the power steering has come apart on. The problem is that the power steering hydrolic cylinder has come loose. The pin that holders the ram in the anchor block has sheared...
  15. C
    MF 50 Diesel problem
    My 65 MF 50 diesel will run for a few minutes and then shut down. It値l start back up after a while, but same issue. Any ideas?
  16. C
    Alternator for 65 Massey Ferguson 50
    I need a replacement for a Delco Remy model 1100424 alternator for my 65 MF 50. Any ideas?
  17. F
    Post driver for MF 50
    Hydraulic question for plumbing a Shaver post driver to a MF50. Do I need any valves, or can I just hook up the hyd supply, unscrew the tranny fill plug, drop the return in that hole and start...
  18. F
    MF 50 Tricycle Tractor
    My dad owns this great little MF 50 tricycle tractor and I've been looking everywhere for information on it. Everything I have found thus far shows a 50 with four wheels and this one has three...
  19. R
    Help Identify this steering part from MF50
    I hope someone can help on this. I know what its called, but the dimensions of my part are causing issues with replacing this work out part. The part is from my 1963ish MF50 high clearance...
  20. S
    Massey Ferguson MF50 fuel gauge
    I am new here. I am trying to find an aftermarket replacement fuel gauge that will work with my MF50 diesel. I purchased the sending unit from yesterdays tractors, but they did not have the gauge...
[ad placeholder]
User Reviews (3)
Read what TractorByNet members think about the Massey Ferguson 50_4 Subcompact Tractor
5
0 %
4
33 %
3
67 %
2
0 %
1
0 %
4.00 star(s)
toolmanbird
50_4 Massey Ferguson
MF50
Model Year: 1964
This is the second model 50 I've owned. I personally believe it is the perfect mix of size to power for a small farm (my buddies like the model 35 more so I had to be different, lol).
Pros: No computerized stuff! :)
Cons: Finding reasonably priced parts compared to the model 35.
3.00 star(s)
bluef100
New Old Tractor
Model Year: 0
Just traded up from 1950 Ford 8N to a 1962 MF50 with the Perkins diesel. I used tractor for mowing pasture. This tractor has a lot more power.
Pros: Diesel.
Cons: Don't know much about the mechanics of this tractor.
3.00 star(s)
larwat
MH50
Model Year: 1957
Not a bad old tractor. Needed something to keep me busy.
Pros: Loader and Bushog works.
Cons: Old.
[ad placeholder]
Massey Ferguson 50_4 Owner Pages
View owner pages to see photos, customization and comments about member-owner Massey Ferguson 50_4s
Massey Ferguson 50_4 Community Rankings
#766 user rating of 2355 25-50 HP Tractors items
#103 Viewed of 2355 25-50 HP Tractors items
#55 discussed of 2355 25-50 HP Tractors items
#2186 user rating of 19625 items overall
#219 Viewed of 19625 items overall
#105 discussed of 19625 items overall
