Farmtrac 60_3 4.30 star(s) (3)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Farmtrac 60_3.
25-50 HP Tractors
About the Farmtrac 60_3
Farmtrac 60_3 Discussions (49)
Here are the most recent 60_3 topics from our community.
  1. G
    Farmtrac 60 Ignition Switch
    I received an ignition switch for a Farmtrac 435 instead of a 60. Will this switch work on a Farmtrac 60 and if so, where can i find the wiring diagram for this switch?
  2. L
    Farmtrac 60 hyd. Help
    Hooked up wood splitter today and no pressure. The hydraulics had been acting slow and jerky over the summer. Fluid is milky. 3 pt hitch will barely lift unloaded. I unscrewed the hyd filter and...
  3. S
    No Longer Available * Farmtrac 60 Operator's Manual *No Longer Available
    For Farmtrac 60 owners I have posted a copy of my manual in a .pdf file. Even though not as extensive as a service or parts manual it provides lots of useful information for the Farmtrac 60...
  4. B
    Farmtrac 60 runs wide open
    I inherited a Farmtrac 60. It has been sitting for around 6 years. Got it to crank but appears to be running wide open on 2 cylinders. It has a Bosch inline injector pump. I replaced the oil in...
  5. P
    My Farmtrac 60 WON'T CRANK......
    Won't crank...tries but acts like not enough battery. Replaced battery & starter still won't turn over. Pulled INJECTORS and it turns over just fine. No funny noises, injector pump working...
  6. B
    FarmTrac 60 Starter Removal
    Anyone removed the starter to clean the pinion as specified in the operators manual? I'm having trouble getting the rear bolt. Jim in SC
  7. S
    Farmtrac 60 Low Pressure Hydro Return Line Leak
    Running any tractor in the woods is prone to cause problems. My Farmtrac 60 has developed a pretty good leak of hydraulic oil from the right side of the differential where the low pressure return...
  8. C
    Farmtrac 60 Stabilizing chain
    Unfortunately I have lost the original equipment stabilizing chain and turnbuckle off one side of my 60. I would like an original to replace it or one of the same design. I have searched the web...
  9. F
    Backhoe Good Backhoe for Farmtrac 60?
    This year I am in the market for a backhoe for my tractor. I plan to use the backhoe for ditch digging and ditch maintenance. I have one large ditch to maintain. It is about 1/4 mile long and...
  10. L
    Farmtrac 60 problem
    Tractor has always started and ran great. Bushhogging today and it started losing power. Would barely run under no load. Noticed white exhaust intermittently. Drained fuel filters and added diesel...
  11. S
    Farmtrac 60 Tie Rod End Dust boot Replacements
    I need to replace the tie rod end dust boots on my Farmtrac 60. Does anyone know of a suitable replacement? Thanks.
  12. S
    What loaders fit a Farmtrac 60?
    My tractor has a Long 5320 loader mounted. What other manufacturers make loaders that fit the farmtrac 60? Where can parts be purchased for the Long 5320 loader? Thanks, Jim
  13. S
    Farmtrac 60
    Does anyone have any input as to whether or not a person should invest in a Farmtrac tractor, considering their problems? I have an opportunity to buy a 2003 60 with loader, rotary cutter, box...
  14. S
    2009 update on my 2003 Farmtrac 60
    New items are in bold. Near 375 hours. Didn't use the tractor as much since my trails are all cut and all I need to do now is mow a couple of times a year, haul firewood. This list is also...
  15. 7mmrum
    Pricing on a Farmtrac 60
    Guys, My dad saw this along the side of the road and didn't know if this is a good deal or not? Farmtrac 60 2001 180hrs 2wd - no implements - no loader $10,000.00 Sounds like a good price, but...
  16. T
    Farmtrac 60
    I am looking to find a way to bypass the starter neutral safety switch on my 60.It seems that it is getting very picky as to when it will or won't start.Sometimes just jiggling the shifter and it...
  17. G
    Hydraulic bleeding valve location farmtrac 60
    I replaced hydraulic line going to cylinder on front end loader after finishing it will not move at all I don't know where bleeding valve is located on the tractor or the best way to go about...
  18. S
    Farmtrac 60
    need head tightening sequence and torque for head bolts
  19. T
    Farmtrac 60 loader hydraulics are slow to work
    I have a Farmtrac 60 that the Long 5320 loader hydraulics are slow to work?
  20. T
    Parts for Farmtrac 60?
    Father in law has a Long Farmtrac 60 and all the local tractor places say they can't get parts. I'm needing sleeves and pistons. Have serial from engine and chassis if it helps. I've searched on...
[ad placeholder]
User Reviews (3)
Read what TractorByNet members think about the Farmtrac 60_3 Subcompact Tractor
5
33 %
4
67 %
3
0 %
2
0 %
1
0 %
4.00 star(s)
marhar
60_3 Farmtrac
FarmTrac 60
Model Year: 0
It is a tough tractor for the money. Parts can be a little hard to find. It is the same as an out of production Ford, but it has been a few years since FarmTrac has been sold in large quantities in the US. I wish some dealers would open up in the states.
Pros: Value.
Cons: Parts.
4.00 star(s)
marhar
60_3 Farmtrac
It Is A Shame They Do Not Make Them Anymore
Model Year: 2002
Farmtrac made a solid tractor. It had few bolts that needed tightening when we first got it. Ours has low hours on it. It is reliable and more than enough power for most jobs.
Pros: Price and reliability.
Cons: Getting a little hard to find parts.
5.00 star(s)
Anonymous Poster
60_3 Farmtrac
Farmtrac 60
Model Year: 1999
I bought from a friend who was quitting his hobby farm. It was 5 years old and had 318 hours. It was stiff and the seat had been eaten by his horse. I have greased, replaced seat, fixed lights, throttle linkage and added a canopy. It has loosened up and now works like its DNA donor the 3910 Ford. Tractor is 3910 except for rear end which is built heavier.Handles 7ft. disc mower with ease and is very fuel stingy. Great utility tractor just not quite the class of the old 3930 Ford.
Pros: Economy
Cons: Long out of business
[ad placeholder]
Farmtrac 60_3 Owner Pages
View owner pages to see photos, customization and comments about member-owner Farmtrac 60_3s
Farmtrac 60_3 Community Rankings
#491 user rating of 2355 25-50 HP Tractors items
#191 Viewed of 2355 25-50 HP Tractors items
#135 discussed of 2355 25-50 HP Tractors items
#1244 user rating of 19625 items overall
#420 Viewed of 19625 items overall
#295 discussed of 19625 items overall
#10 Ranking of Most-OwnerPages in 19625 items overall
