Iseki TX2160_2 4.00 star(s) (1)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Iseki TX2160_2.
Under 25 HP Tractors
About the Iseki TX2160_2
Iseki TX2160_2 Discussions (15)
Here are the most recent TX2160_2 topics from our community.
  1. Q
    Check my work - re-plumbing hydraulics on Iseki TX2160
    Background: I have an Iseki TX2160 with a Loader attached that has not been plumbed properly. It has a 2 spool Walvoil SD5 valve block, which has pressure feed taken off from the banjo bolt of...
  2. M
    Iseki TX2160 K3A Engine starting issues
    Hi All, I am hoping there maybe someone that had a similar issue or some expert wisdom out there to help with diagnosis. When I try to start the engine it turns over slowly and I get grey /...
  3. I
    Iseki TX2160 axle
    Hi, Just joined so Hi everyone. I've just managed to destroy my Iseki 2160, basically the loader took the weight but the front axle sheared at the hub. So after a bit of help from the experts: 1)...
  4. P
    Buying Advice Iseki TX2160 vs. Iseki TX1510
    I'm new in the forum and before posting my question I'd like to say Hello to everybody. I live in Portugal and I've been exploring the Internet for a compact tractor with a loader. I found a...
  5. B
    Iseki TX2160 4WD axle steering joint
    I have a TX2160 with what seems to be a less common axle steering joint layout. All the manuals I can find show the following structure: Mine is like this: Using two pairs of bevel gears and a...
  6. chrismac
    Sump gasket material, Iseki TX2160 making a replacement
    Having made a replacement gasket out of a hard gasket material while I have been sorting out my tractor, I now have a small leak from the sump gasket, would cork be a better alternative to the...
  7. chrismac
    Iseki tx2160 clutch reassembly help, lower spline
    I am in the process of rebuilding my 2160 and tonight have come up with a small battle with the lower spline to the front diff, is there an easy way to get this back in place, I have wrestled with...
  8. T
    Bolens/Iseki TX2160 voltage regulator
    I have a Bolens Iseki TX2160 with a k3b Mitsubsihi engine. I need a voltage regulator for this tractor. The alternator is a Mitsubsihi AH2035M4. (35 amp) Can anyone tell me the correct voltage...
  9. T
    Iseki TX2160 HST- Alternator I.D. and Connection
    The wiring from the alternator in my Iseki has separated where it had been joined by a previous owner. The alternator has only 2 wires coming out of it, and they're both green. The original...
  10. N
    Iseki TX2160 hydraulics
    Hi all, Just bought a little TX2160 mainly to do some mowing at home. I bought it as a non runner that had sat around for about 5 years, I have managed to get the engine running and replaced all...
  11. R
    Iseki TX2160
    HI..I have just purchased my first ever tractor! I have a smallholding of 10 acres which has some drainage problems the little tractor has a loader and backhoe, so im looking forward to...
  12. J
    iseki TX2160 fuel problems
    Hi this is my grandads tractor he has a little one acre allotment (keeps him out of trouble in retirement) We have been having a problem where it wont start. There seems to be getting air in the...
  13. J
    Oil & Fuel Iseki TX2160
    Hi I am having problems with the hydraulics on my 2160. They work to start with, as long as the engine is on full revs, but after a short period of time they just stop working. The TPH will move...
  14. shvl73
    Iseki TX2160
    Does anyone have any info about this model. There is one on E-bay now and it is local. I was thinking of going to look at it. Anything you can tell me would be appreciated.
  15. shvl73
    Iseki TX2160
    Does anyone know if this unit, Iseki TX2160, is considered an "orphan" partwise? There is one for sale locally and I was thinking of looking at it. I just don't want something that has terrible...
[ad placeholder]
User Reviews (1)
Read what TractorByNet members think about the Iseki TX2160_2 Subcompact Tractor
5
0 %
4
100 %
3
0 %
2
0 %
1
0 %
4.00 star(s)
Bill McQuiston
TX2160_2 Iseki
Tough Little Tractor
Model Year: 1984
I bought this tractor used. It has Bolens repackaging. It is a tough little tractor and I have to say I've used/abused it quite a lot. It will lift more than 500 pounds in the loader. It pulls whatever I want. I have hauled dirt, sand, rock and tree stumps in the loader. It has a variety of add-ons such as: loader, grader blade, snow thrower, plow and it used to have a mower which I sold. I have been very pleased with this tractor but it has aged and is starting to need some attention.
Pros: Versatile, strong, good hydraulics, nimble, easy start.
Cons: Weight---too light, diesel and Minnesota weather, hard to find parts.
[ad placeholder]
Iseki TX2160_2 Owner Pages
View owner pages to see photos, customization and comments about member-owner Iseki TX2160_2s
Iseki TX2160_2 Community Rankings
#196 user rating of 731 Under 25 HP Tractors items
#179 Viewed of 731 Under 25 HP Tractors items
#109 discussed of 731 Under 25 HP Tractors items
#1380 user rating of 19625 items overall
#1421 Viewed of 19625 items overall
#673 discussed of 19625 items overall
