Willl
Elite Member
Nunyabinis, your kidding, right ?
Negative. Why would you think I'm kidding?
That's my typical load heading to the Hunt Club for a Work Weekend. 6k lbs on a 7k trailer. Just what the doctor ordered.
I think he is refering to how you have your tractor boomed down. The way you have it doesn't quite pass muster.
I'm not sure you've got enough trailer there, Foreman.
That's a mighty Big Load. :laughing:
Tiedowns (chains and straps) are strongest at right angles to the load, but in order to resist force in both directions, they should be 45 degrees to the load.It has four 10,000 lb break-strength straps attached to the loader supports holding it in place. Each strap has a working load of 3,333 lbs. I've made a dozen trips and the rig hasn't moved an inch.
Yeah, it COULD break loose, but, an asteroid COULD wipe us all out tomorrow.
16ft tandem trailer; JD 3038e; 6ft flail mower; 5ft tiller; fuel cans; weed eater; cooler of adult refreshments and chainsaw in the metal box. 600 lbs of weight on the tongue.
Ready for work.
Ill never use a fabric strap again after i had one tear on my while hauling a mini excavator. Nowdaze (for past 5-6 years) i use only 5/16" binder chains and ratchet binders....period.
