How much weight can I legally haul in Virginia without CDL.
   / How much weight can I legally haul in Virginia without CDL. #31
If only that were true.
It is true ... no "if" needed ...
I am pretty sure I cannot go buy a lowboy and tractor and tow 80k for my own personal needs (not commercial) without a CDL.
The actual problem would come when you tried to register and plate it ...
Commercial registration and plates = commercial use ... ;)
   / How much weight can I legally haul in Virginia without CDL. #33
Chris - Look at some older ones.<img src="http://www.tractorbynet.com/forums/files/trailers-transportation/422823-how-much-weight-can-i-99tow-ratings-jpg"/> '99 Fords were limited to 20K GCVWR and 10K tow. For the OP - check this thread http://www.tractorbynet.com/forums/trailers-transportation/231776-can-you-up-rate-new.html. I think if you keep it clean, well tied down, and look like you know what you are doing you won't be stopped. Just keep the CB on to lookout for when they are stopping EVERYBODY (orange alert, DUI checkpoints, etc.)
I had a 99 350 SRW 7.3 but I didn't realize the Dually was rated the same as a SRW truck.
Chris
   / How much weight can I legally haul in Virginia without CDL. #34
Nope ...
Again, nope ...
Can you elaborate?
This whole CDL thing is as confusing to me as the tax code.
I have read and read more. I am currently looking into getting a CDL because everything tells me I need to. 12.2k GVWR truck, and a 12 ton GN trailer. By my understanding, I need a CDL regardless of my purpose for towing. And a CDL A to boot.
Following flow charts and reading various laws, the only time I see 10,001 mentioned is determining Class A or Class B when truck is over 26k.
Hard to imagine a guy with a 3/4 ton truck (or even these newer 1/2 tons) towing a 12k bumper pull trailer and needing a CDL of any kind.
   / How much weight can I legally haul in Virginia without CDL. #35
Can you elaborate?
Sure ... although I now understand you to have meant trailers (towed vehicle) rather than the towing vehicle when you referred to 10,001 requirement.
I was referring to the towing vehicle, not what is being towed.
Regardless, that is neither here nor there.
Basically any vehicle (used in commerce) over 10,001 lbs is considered to be a Commercial Motor Vehicle (aka) ... and is very highly regulated by the Feds.
Note that - for the Fed's (and probably most states) purposes - Commercial Motor Vehicle is not the same thing as a commercial vehicle ...
IOW, you can have a commercial vehicle (registered and plated) and not fall under the same regs as Commercial Motor Vehicles.
That describes my own personal situation (a van which has a GVWR of 8550 lbs - but is used in commerce and is registered and plated as a commercial vehicle)
I don't log or scale (except in certain rare states, Virginia being one)
Much misinformation exists out there that's for sure.
The following is from the Feds (Federal Motor Carrier Safety Administration), and I have highlighted applicable/noteworthy portions:
Drivers have been required to have a commercial driver's license (CDL) in order to drive certain commercial motor vehicles (CMVs) since April 1, 1992. The types of vehicles and operations requiring a CDL are outlined below. The Federal Motor Carrier Safety Administration (FMCSA) has developed and issued standards for State testing and licensing of CDL holders. These standards require States to issue CDLs to certain CMV drivers only after the driver passes knowledge and skills tests administered by the State and related to the type of vehicle the driver expects to operate. Drivers are required to obtain and hold a CDL if they operate in interstate, intrastate, or foreign commerce and drive a vehicle that meets one or more of the classifications of a CMV described below. ...
You can read more at the link below:
Drivers - Federal Motor Carrier Safety Administration
The relevant point (above) is that the requirement for a CDL is for drivers operating certain vehicles being used in commerce.
If you are driving/towing/hauling using that setup, then yes you do ... assuming that you are doing it for a commercial reason and are engaged in commerce ...
   / How much weight can I legally haul in Virginia without CDL. #36
IF It's not for Commerce (making money) it doesn't matter, no CDL required.
as noted, CDL is an endorsement for commerce. You might rephrase your question "how much weight can i legally haul in VA on a standard class C/D license"
if this is your rig
assuming that trailer is over 10,001 lbs, and that FL60 has a GCWR over 26,001 (it does at something like 60,000 lbs depending on setup)
your going to need a class A license.
Put another way.
If your tow vehicle is GCWR less than 26,000... then you can haul up to that weight on a regular drivers license. 16K trailer on a 9999lb truck. a 11K trailer on a 14,999 truck etc
This is assuming all other ratings are met. (you actually have a trailer with a 16K GVWR, you dont exceed the RAWR of the tow vehicle etc)
   / How much weight can I legally haul in Virginia without CDL. #37
Last fall I went to DMV (Virginia) and registered my Ram 2500. The lady asked what I was doing with it (Personal towing) and how much I wanted to tow (14k trailer).
She gave me plates to suit and noted since it was under 26k combined, my regular license was fine.
That was that.
   / How much weight can I legally haul in Virginia without CDL. #38
My understanding is that I need a CDL even if NOT doing it for commerce. If I am towing a tractor to my house to a friends, I would still need a CDL.
From everything I have read, A 1-ton truck with a 24k GN trailer is no different than a semi w/53' box. No matter weather commercial or private.
   / How much weight can I legally haul in Virginia without CDL. #39
Yeah ... I "get" what your understanding is ...
Dunno where (or what) you're reading ... so I can't really comment on that ... other than to say on the face of it - without you providing additional qualifications - it's wrong.
If you have a source you'd like to cite, I'll be happy to have a look.
I've provided you with one source already - which is the ultimate Federal authority on CDL's - the United States Department of Transportation, Federal Motor Carrier Safety Administration.
The only potential issue I can see is that the State of Ohio registers non-commercial trailers by unladen weight. They do this up to a unladen trailer weight of 10,000 lbs:
ODPS | BMV | Non Commercial Trailer Registration Fees
Unladen weight is different than GVWR .
So yeah ... if the unladen weight of your 24K GN exceeds 10,000 lbs., the State of Ohio will require you to register it as commercial, which opens the whole CDL can of worms.
   / How much weight can I legally haul in Virginia without CDL. #40
The unladen weight is 6500#, but I think it is tagged as commercial. They didnt even ask me if I wanted comm or non-comm. And didnt realize til I got home and installed the plates. Renewal is up in a few months. Comm is cheaper, only ~$45. Going non-comm @ 6500# puts me $91.
I have done tons of reading at the cites you already posted. I still have yet to read anything that excludes a person from those weight restrictions if you are non-commercial.
If I understand YOU correctly,
1. You are saying that if truck and trailer are registered non-comm, and I am hauling for personal use, I am fine with no CDL.
2. But if registered comm, or hauling commercially, I need the CDL?
3. And if I had a trailer with a GVWR under 13.8k (12.2+13.8=26k) I wouldnt need a CDL regardless?
If only I could be certain.
Ohio's CDL flow chart looks the same as the one posted earlier.
Does the vehicle or combination of vehicles have a mfg weight rating over 26k? 12.2+24k=36.2k.............Yes
Is the vehicle a combination vehicle towing a unit with a GWVR over 10k.......YES
CDL A required
I see no exemptions for non-commercial use?
And there are a TON of other threads on the net all across the US Asking these same questions. A 1-ton with a dual tandem or triple axle GN require a CDL. And the general consensus is YES. And lots of people telling stories of being pulled over towing their old tractor from one farm to the next, or hauling cattle, etc.
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
2020 INTERNATIONAL TANDEM AXLE SLEEPER (A58017)
2020 INTERNATIONAL...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A56438)
2022 Schulte...
Bell 1600 Gallon Nurse Trailer (A56438)
Bell 1600 Gallon...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
2017 Ram 1500 Pickup Truck, V6, 4X4, Automatic Transmission, 212,570 Miles (A56438)
2017 Ram 1500...
